Old 02-09-2013, 11:21 PM   #1
dirish
dirish's Avatar
01-06 Tahoe seatsin C10?
Anybody? It would solve my shoulder belt
Issues as well. How hard/ easy. Pictures?
Thanks!
dirish is offline   Reply With Quote
Old 02-09-2013, 11:36 PM   #2
BionicABs1
Re: 01-06 Tahoe seatsin C10?
I did 2 buckets and built a console. I'll try to find a pic.
BionicABs1 is offline   Reply With Quote
Old 02-10-2013, 01:18 AM   #3
LSUMurse
LSUMurse's Avatar
I put some in that I was told were from a Tahoe. The part number sheet said they were made in '05.
The job isn't too difficult. They do not match up to any of the original bolt holes. I used a 1/8" C channel from Home Depot as backing for the bolts. I will eventually go back and weld them to the floorboard for added strength.
They are rather comfortable. The only issues I can say I have with them are:
They are a little close to the steering wheel. I plan on sliding the steering column a little closer to the dash to help fix this problem, but that will also bring it closer to my knees. I am 6'2", so this may not be a problem for everyone. I will probably end up having to get a tilt column.
Also, if you put the center console down, you see the fuel tank. Not a problem if you've moved it. I plan on buying a carpet to cover the tank.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 02-10-2013, 09:10 AM   #4
dirish
dirish's Avatar
Thanks guys! Anyone else.
Old 02-10-2013, 09:55 AM   #5
Wootdog
Wootdog's Avatar
I put 98 Pontiac Bonneville Gray Leather buckets in my 67. 9 way power on both. Funny thing is there is no need for the power. Not enough room anyway. 100 bucks on Craigslist. And to be honest, there are alot of Bonnevilles in the Salvage yards nowadays.
Kerry
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 02-10-2013, 10:22 AM   #6
dirish
dirish's Avatar
Kerry
Is your tank behind the seat still? Found set of tahoe for 100.
Waiting on pictures. Wanting a solution to not having a shoulder
belt. Built in, plus comfy seat is a bonus. Car seat is also a consideration.
Old 02-10-2013, 10:23 AM   #7
dirish
dirish's Avatar
Im thinking this is what i want! Looks sweet, i see car seat fits in good.
Old 02-10-2013, 10:27 AM   #8
Wootdog
Wootdog's Avatar
I guess I should have stated earlier. I relocated my tank to between the frame rails. The filler is in the left rear fender. I may be able to get some pics later today. I will need to pull Peppy out of the garage. No shoulder belts. One of the belts originally was in the seat on the inside. I removed them. Just lap belts. The seats are really comfortable. And the outside bolt holes lined up but not the inside ones. I did like the others did. I drilled a hole for the inside bolts and put a long piece of flat steel underneath to keep them from pulling out.
First I got to go to PicknPull with the neighbor. There is a 70 C10 and a 00 Silverado on the Yard. We don't see them much around here.
Kerry
1969 Chevelle
2002 Silverado LT
Old 02-10-2013, 10:39 AM   #9
hugger6933
Those type of seats have been used countless times in these truck, the main complaint is the lack of room in there. That is the same thing I found when I put some in as well. I am 6'2 and go in almost 400 lbs but I not fat I am just under tall for my weight.
hugger6933 is offline   Reply With Quote
Old 02-10-2013, 10:56 AM   #10
dirish
dirish's Avatar
6'0 and shrinking. Lol im thinking this the route im taking.
Old 02-10-2013, 11:36 AM   #11
Tinkermc
got mine from a Grand Am with built in seatbelts, I put in a tilt and a smaller sterring wheel room is no longer a problem with the tank moved,for now the tank is only removed not replaced I'm only 5'10"
Tinkermc is offline   Reply With Quote
Old 02-10-2013, 12:35 PM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Here is a pic of the seats you are looking at installed.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is online now   Reply With Quote
Old 02-10-2013, 12:36 PM   #13
72 K20
72 K20's Avatar
Check out this article,, might be a solution ! These brackets are for the 95-98 buckets but might work or be adaptable !
http://67-72chevytrucks.com/vboard/s...+seat+brackets
72 K20 is offline   Reply With Quote
Old 02-11-2013, 07:45 PM   #14
dirish
dirish's Avatar
Very nice!
Old 02-11-2013, 08:05 PM   #15
sprint_9
sprint_9's Avatar
Originally Posted by dirish View Post
Very nice!
I agree.
This is the style of seat Im putting in my truck when I start on it.
sprint_9 is offline   Reply With Quote
