02-09-2013, 11:36 PM | #1 |
reverse issues .. HELP
every time i put my truck in to reverse .. it jerks real bad any ideas why ... Thanks in advance
1969 C20 CUSTOM "RUMBLEr" |
02-10-2013, 01:12 AM | #2 |
Re: reverse issues .. HELP
Possible
bad u joint to high of idle slop in the rear differential [just a few things to check]
Fuzzy |
02-10-2013, 01:18 AM | #3 |
Thanks alot ! I know it's not the the Idle ill check the other things out
02-10-2013, 01:40 AM | #4 |
Check your fluid level, too. Too much or too little can cause a wide variety of abnormal conditions of operation, with none of them having favorable outcomes.
Also, motor mounts and/or carrier bearing- slop there can allow harsh engagement issues. Posted via Mobile Device
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
02-10-2013, 01:22 PM | #5 |
I am a Referee of life.
Might also want t check the carrier bearing.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
