Cab floor.... strange find? maybe...
hey guys, today I decided to pull out my seats to work under the dash & got a wild hair up my rear to just pull out the carpet as well...
Maybe someone can help fill me in on some things I found that I know nothing about... Pictures say a 1000 words. WHAT WHERE THE 3 RAISED AREAS IN THE FLOOR USED FOR? ALSO, WHAT IS THAT PIECE BOLTED TO THE FLOOR USED FOR? WHAT ARE THESE TWO BRACKETS USED FOR? Also I have to ask, did 68 cabs come with the 2 lower knobs for the gas pedal? Mine has them.... Any wisdom on this topic would be grateful..... Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
![]() Join Date: Apr 2008
Re: Cab floor.... strange find? maybe...
Scott,
I can only help with the last, a 68 would have had a floor mounted pedal and the ball studs are how they mounted. I also gotta say thanks for the first pic. I have wondered if the 2 sheetmetal screw just forward of the fuel line were for.....now I know. Shane |
![]() Join Date: May 2010
I'll take a guess.
I believe the 67s and 68s had the jack and tools stored under the seat. The bracket bolted to the floor on the hump would have had a spring with a large ring attached to secure the jack to the floor. The other brackets probably were to secure the tools. 69 and up had the tools in the right cab corner and the jack on the floor beside the gas tank. What year is your truck? |
![]() Join Date: Oct 2010
I remember as a kid our truck had the jack handle in a bracket like that. I think that is what you have also.
#5 | |
Roadtrip!
![]() Join Date: Feb 2003
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Mystery solved... I found a few images searching around on the forums...They explain it pretty well.
Here are the threads where I got the images from... Mystery Brackets... Jack Hardware Placement... Cheers... Scott
