Old 02-10-2013, 10:44 AM   #1
85burb
85burb's Avatar
Throttle cable help
I need help on what y'all are doing with throttle cables. I have two swaps that need a cable. Both 85 Chevys. On a burb and one a long bed. A guy at work used a stock camaro cable on his el camino. Just seeing what y'all are using. Thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-10-2013, 11:26 AM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Throttle cable help
I used a stock 99 silverado cable on my 67.
Bolted a piece of flat steel to the injector rail bolt welded a washer w a slot to the end to hold the outer part of the cable. Then welded a matching washer w a slot for the end of the cable to slide into on the end of the gas pedal linkage.
Pretty simple setup that seems to work great.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 02-10-2013, 03:14 PM   #3
whitels1
whitels1's Avatar
I used a cable for a 2002 Avalanche and mated it up with an Fbody bracket.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 02-10-2013, 07:40 PM   #4
mooseknuckles
mooseknuckles's Avatar
bought a lokar one off of ebay $60
mooseknuckles is offline   Reply With Quote
Old 02-10-2013, 08:15 PM   #5
85burb
85burb's Avatar
Part number of eBay lokar?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2013, 08:51 PM   #6
mooseknuckles
lokar tc1000....36"
Old 02-10-2013, 08:56 PM   #7
85burb
85burb's Avatar
Originally Posted by mooseknuckles View Post
lokar tc1000....36"
It hooked up to throttle body and pedal with no mods?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-11-2013, 01:06 PM   #8
OldCreek
OldCreek's Avatar
For my '72 I used the stock '72 cable and the stock 5.3 mount. Easy.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-11-2013, 03:49 PM   #9
bohmankid
bohmankid's Avatar
I got the same Lokar cable as moose, and it required extensive modification to work for me (I will not buy it again, mostly because it is so expensive and I cut it up anyway). I had to cut off one end and mix and match parts off the stock cable from my 85. I used the pedal out of my 85 gmc. It works great now though.
bohmankid is offline   Reply With Quote
Old 02-13-2013, 02:05 PM   #10
85burb
85burb's Avatar
After 30 mins of arguing with orileys and autozone I ordered one from chevy. 36 bucks. It is from a 01 chevy truck. Hope it works. Orilys tryed telling me 99-03 only came with electric throttle body's. we all know that is wrong. So we will see if it will work. Thanks for the help.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-15-2013, 08:17 PM   #11
85burb
85burb's Avatar
I got and installed my factory throttle cable. Went in with no problems. Only had to sand where it clips to firewall to get it in. clipped right on to the 85 pedal. I got part number 15040848 from my local chevy dealer for 33 bucks. Now all i need is the bracket that bolts to the intake to hold cable in place.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-14-2014, 07:49 AM   #12
79 big block
I know this is an old thread but thank you 85burb for posting that pn, I've been trying to figure out which cable to use.
79 big block is offline   Reply With Quote
Old 03-14-2014, 11:09 AM   #13
Matt Cramer
3' mountain bike brake cable - cost under $15 from a local bike shop and fit the LS throttle pretty well.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 03-14-2014, 12:21 PM   #14
79 big block
I had seen that somewhere else, don't remember where. Thanks I will give it a try. I'm all for saving some money.
Old 03-14-2014, 03:42 PM   #15
Matt Cramer
One end is swaged on at the throttle body; I used a cable knarp end (with a set screw) at the gas pedal.
Matt Cramer
4.8 LS build thread
Old 03-14-2014, 04:21 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
knarp
I had to google this word, and can't stop giggling when I say it.
*knarp*
heheheh
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-14-2014, 04:38 PM   #17
79 big block
It is fun to say isn't it.
Old 04-29-2014, 07:10 PM   #18
79 big block
Thanks Matt for the tip again on the brake cable, I have less than $15 in it and it works great.
Old 04-30-2014, 09:12 AM   #19
littlevictories
make sure to ask for a MTB style brake cable and not a road style.
knarp knarp knarp
littlevictories is offline   Reply With Quote
Old 04-30-2014, 05:27 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by littlevictories View Post
knarp knarp knarp
indeed
Old 04-30-2014, 06:49 PM   #21
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Throttle cable help
Hawks used the Lockar cable and didn't put the set screw in it are either it came out. I noticed last week it didn't feel the same. Hince I say it came out but who knows.
I went and bought some small cable and crimp connectors and used my crimper to get it tight. Works fine now and has a lot better kick down when you hit the pedal. The 71 pedal is nice and firm now also. Before it was mushy feeling.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-30-2014, 07:01 PM   #22
79 big block
I used two knarps at the pedal end and used a barrel adj at the throttle cable mount for adjusting the tension
