Old 02-10-2013, 02:30 PM   #1
48gmc
adhesive
want to glue rubber to aluminum, what to use,and where to buy it?
48gmc is offline   Reply With Quote
Old 02-10-2013, 03:30 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: adhesive
I've recently used 3M weather strip adhesive(gorilla snot when I grew up) on the window channels for my one piece windows. I found it to be messy and pretty unforgiving in that application, but it did stick. When I had to fine tune the channels and put in the special window felts I used black silicone adhesive and masking tape + wedges of wood to hold things in proper place for 12 hours or so. The clean up was much easier and the fittment way more forgiving because it doesn't set up so fast. I also think there's an advantage in that it's a very good adhesive but dries flexible. For vehicles and vibration, I think that's an advantage. Love to hear some other opinions.
Speedbumpauto is offline   Reply With Quote
Old 02-11-2013, 05:56 PM   #3
lazypineapple
lazypineapple's Avatar
Re: adhesive
Yup 3m weatherstrip adhesive.
Ruff up the metal alittle. Apply adhesive to both piece.
Then stick together
lazypineapple is offline   Reply With Quote
Old 02-12-2013, 11:37 AM   #4
solidaxel
solidaxel's Avatar
Re: adhesive
I keep a tube of silicone (calking tube size) on hand that I pick up from the Auto Glass store, cost was about 11.00 but if you keep it closed it will last a long time.
I have found this stuff to stick to everything so be careful where you place it as it is hard to remove, once it sets up.
DO NOT get it on any painted surfaces as it will be the last time you see the paint!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-12-2013, 02:14 PM   #5
blackdiesel
blackdiesel's Avatar
Re: adhesive
windshield urathane will stick anything to anything
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
