Old 06-13-2003, 02:24 PM   #1
72MARIO
72MARIO's Avatar
How to test a Tach ?
I have a cluster I picked up for 35 bucks and I want to see if the tach is any good thanks for the help. It is a 8cyl tach.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-13-2003, 02:42 PM   #2
jays68yak
jays68yak's Avatar
Send it to me, Ill put it in my truck and let you know if it works.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 06-13-2003, 02:42 PM   #3
cojnit
Nothing clever
cojnit's Avatar
tach
if you have a cable, attach it to a drill.
cojnit is offline   Reply With Quote
Old 06-13-2003, 06:15 PM   #4
Rod
I just take the harness and connect it to the tach head... take the red wire to the battery post and the brown wire to the coil...hmm negative side... and ground the bezel metal case to the rad cradle when I'm testing them, beats installing them.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-13-2003, 06:58 PM   #5
turmoline
I just installed my tach dash and could only get 2500 rpm max. It worked prior to the rebuild of the truck. I hooked up the green to the negative side of the coil and the red or pink I think to the ignition unfused in the fuse block. There are 2 terminals one side didn't work the other works but can only get 2500 rpm out of it. Is that the wrong place for the switched ignition wire?
turmoline is offline   Reply With Quote
