Old 02-10-2013, 09:15 PM   #1
elks
Blower motor???
So i noticed that my blower motor blows... I mean not really at all.
What are the options for an up grade. I can barely feel it when on High...
It is a truck with AC
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 02-10-2013, 09:26 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Blower motor???
Have you cleaned out the debris from the heater box lately ?
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 02-10-2013, 09:46 PM   #3
Billett
Billett's Avatar
Re: Blower motor???
^that helps a ton. Mine was full of stuff. I also found out when I cleaned it that all that junk had chewed up the teeth on the fan.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-10-2013, 09:52 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Blower motor???
Does it blow more (faster) on medium than high? You may have a bad blower resistor board. Try running a wire from your battery to the blower motor and see what happens. If it blows faster than medium speed, then check the resistor.
TBONE1964 is offline   Reply With Quote
