Old 02-10-2013, 10:16 PM   #1
texastrendz
wilwood master cylinder install pics?
Anyone got photos of an install on a 67-72 cab? How it bolts to the firewall and which mounting holes are used.
texastrendz is offline   Reply With Quote
Old 02-10-2013, 10:20 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: wilwood master cylinder install pics?
Here you go,...
Keith
Convert to disc brakes.
Old 02-10-2013, 10:24 PM   #3
texastrendz
Nice, does it cover the entire hole in the fire wall since you only use the bottom holes? Did it come with the adapters you have in the picture on the brake line fittings?
Old 02-10-2013, 10:26 PM   #4
lolife99
lolife99's Avatar
Yes and yes.
Keith
Old 02-10-2013, 10:28 PM   #5
texastrendz
One more question, is it pretty much a bolt in with the brake rod and pedal?
My truck had a power brake setup from the factory.
Old 02-10-2013, 10:31 PM   #6
lolife99
lolife99's Avatar
Mine had manual brakes,... and it was a direct bolt on.
Keith
Old 02-10-2013, 10:38 PM   #7
texastrendz
No problem finding a manual setup, just glad it is a bolt up unit. Thanks for all the fast responses. Going to give Scotts Hotrod a call in the morning and get the order in.
Old 02-10-2013, 10:45 PM   #8
lolife99
lolife99's Avatar
I ordered mine from Jegs.
Keith
Old 02-10-2013, 10:50 PM   #9
texastrendz
He has helped me with some questions I have posted on this forum. Time to pay it foward and spend some money with them as they support the forum. Trying to spread it out with the vendors on the site.
Old 02-10-2013, 11:43 PM   #10
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Justin's a great guy to do business with.
Zoomin is offline   Reply With Quote
Old 02-11-2013, 03:19 PM   #11
68racer
Yeah baby!
68racer's Avatar
lolife, which bore size did you use?
11.37 @116
68racer is offline   Reply With Quote
Old 02-11-2013, 04:07 PM   #12
bruce bruce
Good to see that...I don't think Jeg's is a vendor on here
bruce bruce is offline   Reply With Quote
Old 02-11-2013, 06:49 PM   #13
lolife99
lolife99's Avatar
1" bore.
Keith
Old 02-11-2013, 06:49 PM   #14
lolife99
lolife99's Avatar
Nope.
Keith
Old 02-11-2013, 07:51 PM   #15
wraprail
wraprail's Avatar
1" bore.
I would assume you have 4 wheel disc with that 1" bore?
Hows the pedal?
I'm converting my power to manual and not sure which bore size is best. What calipers are you using?
wraprail is offline   Reply With Quote
Old 02-11-2013, 08:07 PM   #16
lolife99
lolife99's Avatar
This truck is not on the road yet.
My '69 also has a 1" bore M/C with no booster.
It is a disc/drum set up.
Pedal effort is a little more than a truck with a booster,... but I think it's worth it to clean up the firewall.
I'm using Wilwood D52 calipers.
Keith
Old 02-11-2013, 08:44 PM   #17
68racer
Yeah baby!
68racer's Avatar
Thanks.
11.37 @116
Old 02-11-2013, 09:52 PM   #18
texastrendz
Just got off the phone with Justin at Scotts, got a killer price and service. Thanks again board vendors. Its on the way boys and girls.
Old 02-11-2013, 10:05 PM   #19
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Very nice. Be sure to let us know when you get it.
Old 02-11-2013, 10:28 PM   #20
wraprail
wraprail's Avatar
One more question Keith if you don't mind ( and if it's ok with the OP I don't mean to threadjack) are you using an OE (or OE type) combination valve on either truck and if so are you also using an aftermarket adjustable prop valve in addition to the OE valve.
2 questions, sorry.
Old 02-11-2013, 10:45 PM   #21
lolife99
lolife99's Avatar
My stepside has a SSBC prop valve mounted on the frame.
My '69 has a standard disc/drum prop valve that hangs below the M/C.
Keith
Old 02-11-2013, 11:12 PM   #22
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Nice workmanship on the line bending Keith!
Old 02-12-2013, 12:43 AM   #23
wraprail
wraprail's Avatar
Never seen that SSB valve before, nice piece but dude, that is the cleanest work on the lnstall/tube bending I have ever seen. Period. Anywhere. 180 into a 90 that close to a fitting? I would not believe that was even possible. I am seriously impressed.
BTW, thanks for the info....
Old 02-12-2013, 07:46 AM   #24
lolife99
lolife99's Avatar
Originally Posted by wraprail View Post
Never seen that SSBC valve before,....
http://ssbrakes.com/c-407225-shop-by...ortioning.html
Wilwood also makes a cool "distribution system" that is also adjustable.
But I already had the SSBC unit.
http://www.wilwood.com/MasterCylinde...derValves.aspx
Keith
