02-10-2013, 10:48 PM | #1 |
4wd rear end in a 2wd blazer?
how much is involved in putting a 4x4 blazer rear end in my 2wd blazer, is it just a matter of switching the axles? or is there more?
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
02-10-2013, 11:05 PM | #2 |
I know the pieces fit
Re: 4wd rear end in a 2wd blazer?
No difference I can think of. What kind of swap are you looking at?
02-10-2013, 11:11 PM | #3 |
the rear end in my 1980 2wd pinion shaft is really loose. and i have a 1980 4x4 blazer parts truck with a 3.73 that seems to be a lot tighter.
02-11-2013, 02:36 AM | #5 |
resident oilfield trash
Going to look kind of funny with 6 lug on the back a d 5 on the front
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
02-11-2013, 12:44 PM | #6 |
It's pretty easy to pull the axles out of the housing to swap them over to keep 5-lug but I'm not sure if the spline count is the same.
02-11-2013, 12:57 PM | #7 |
67-72 parts collector,…
Install the new rearend with your 5-lug 2wd axles, and you will be good to go.
02-11-2013, 03:15 PM | #8 |
Low & Fast!
That what I did on mine..
02-11-2013, 04:38 PM | #10 |
Sweet no problem then
02-11-2013, 11:45 PM | #11 |
yeah i was planning on swaping the axles between the two.
