8 lug to 5 lug / leaf to trailing arm.... Help please
~72 Chevy Truck~ Motor: LY6 6.0 Liter Trans: 6L80E Still under construction Last edited by Nitschke; 02-10-2013 at 11:12 PM. |
Re: 8 lug to 5 lug / leaf to trailing arm.... Help please
Its a 3/4 ton 8 lug leaf spring truck 411 Dana 60 rear. I am converting it to 5 lug trailing arm setup. I've already cut the frame for short bed and it is getting a No Limits rack and pinion. So im wanting to know how to make this all work? Full guidance woud be awesome. I was given a 75 chevy van 5 lug 3/4 ton 411 open diff rear for parts it has brand new brakes, bearings, ball joints, spindles, $900 tires and aluminum radiator.
I will start a build thread soon! If someone wants to fallow. Posted via Mobile Device
~72 Chevy Truck~ Motor: LY6 6.0 Liter Trans: 6L80E Still under construction |
Porterbuilt has a trailing arm set up that would bolt right in
Posted via Mobile Device |
Thank you. Nice stuff but to much $$$$. I dont have that kind of money to spend on it right now. Im wondering what will work from the 75 van in my conversion and what ells ill need to get. I was thinking i would get the arms from a long bed and shorten them my self. Cuz they are cheap and all over.
Someone on here did a write up on how to make their own arms...Maybe someone has a link? Or you can search for it
#6 | |
#7 | ||
As mentioned, you can take a factory trailing arm x-member and upper shock cross member from a coil spring truck and install it in your leaf spring truck. The trailing arms will bolt right in also.... BUT the trailing arms are different from 3/4 ton to 1/2 ton so you will need to find some specific to the 3/4 ton application.
We understand the "budget" for sure... but we are always willing to help with information or other alternatives. Feel free to give us a call if you would like to discuss the swap. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#9 | |
![]() Quote:
What are the differences in the arms? Posted via Mobile Device
Factory 3/4 ton arms are partially plated on the top & bottom for additional strength.
