Old 02-10-2013, 11:16 PM   #1
richards72chevy
richards72chevy's Avatar
How long should it fast idle?
Im having to drive my 72 to work.I leave at 530 a.m. On cold mornings i notice it idles real fast.How long should i let it do this before i give it gas to slow down the idle?Is the fast idle for engine warm up too?
richards72chevy is offline   Reply With Quote
Old 02-10-2013, 11:45 PM   #2
Olive1970
Olive1970's Avatar
Re: How long should it fast idle?
They will idle quite high on fast idle, sometimes it seems a little high to me also. However, if your choke is working properly you will be able to barely tap the gas to move the step down the next notch on the choke cam. This way, it is still warming up the engine but not running at 3500rpms (or whatever it is) and soon enough down to curb idle.
Gary
Slowly looking for my next 67-72 truck
Olive1970 is offline   Reply With Quote
Old 02-10-2013, 11:49 PM   #3
ole dollor
ole dollor's Avatar
as long as the motor stays running when you tap the throttle you can let it idle at the step down or at normal idle, i not a fan of high rpm on a cold motor..
ole dollor is offline   Reply With Quote
