02-11-2013, 12:17 AM | #1 |
I don't want to build thread (lots of pics)
well I was messing with one of my friends in his new mustang and well all of a sudden i get a huge bag and the truck shuts off. Turns out the balancer decided that it wanted to be in a million pieces, basically it was like a bomb went off under the hood, hole in the hood dents everywhere and everything on the front of the engine was cracked,bent or destroyed. So the front clip has to be painted and well while I'm at I figured I might as well fix every dint scuff and scratch will be fixed.
That Night Little bit of the damage
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 |
02-11-2013, 12:21 AM | #2 |
Re: I don't want to build thread (lots of pics)
So now I have bought a hood and done a little body work
this was one of the worst hoods I've dealt with. I had to weld beat on it to get a decent gap
02-11-2013, 12:34 AM | #3 |
got the bed off and did a little body work
and where it will sit til I get more time to work on it
02-11-2013, 12:49 AM | #4 |
VA72C10
man,that stinks...but looks like you're making it even better! I've heard those cowl hoods don't fit well at all. Hope I can see the truck in person at some point. I am working on setting up a customer in Abingdon so I'll be riding through Wytheville monthly if I do...
Looking for a 67-72 swb or blazer project in or around VA. |
02-11-2013, 02:01 AM | #5 |
Cool truck! I really like the paint job. sucks that the balancer came apart. What are the specs on the wheels and tires? if you don't mind.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
02-11-2013, 12:20 PM | #6 |
wheels are 18s ( 235/40zr18)up front and 20s (255/35zr20) on the back
02-11-2013, 06:19 PM | #7 |
67cheby
wow, that's alot of work on that hood
03-17-2013, 03:19 PM | #8 |
well mad a little progress this weekend put in a ccp c-notch in and a shock relocation in yesterday. everything was actually really easy and simple to do.here are a few pics of the progress.
03-17-2013, 08:17 PM | #9 |
Cpp*
09-20-2013, 03:27 PM | #10 |
I haven't updated this thread in awhile but around the end of August I finally had enough... I was tired of seeing my truck in a tore apart so I got off my lazy but and got to work. Once I really got into it I started to find some problem area I wasn't quite aware of so its been been quite the task. Basically Ive taken the truck almost all the way apart and am painting the entire thing minus the fire wall and inside of the cab. here is just a quick run down and a few pics( mostly taken in the last week or so) of what I've done and what is in the works.
Rust repair rear fenders -mounting flange was replaced doors - bottom skin was replaced door jam-smoothed and small rust areas were replaced Body mods shaved antenna smoothed door jams cut rockers for better alignment LH fender was cut for better alignment replaced seam sealer in gutter Pop up gas cap for wood in the bed rear fender lips rolled for tire and wheel clearance Engine bay and performance new valve covers and breather plugs and plug wires rad cover restored heater box wiring clean up- plug wires routed under headers rewired a few misc. things refinished radiator support custom 3inch tail pipes New top fill gas thank for under the bed Suspension C notch installed rear drop springs (rear total drop 7 inches) shock relocation adjustable track bar In the works New wood for the bed- I think Im going with black walnut wheel tubs for the bed new wheels new seat and door panels repaint the frame tubular control arms new shocks Maybe new mufflers PAINT!!!-no more flames just a straight 2 tone
Corey Jones Designs CoreyJonesDesigns on instagram Ole Silver- 1967 stepside http://www.hotrod.com/articles/1103c...chevrolet-c10/ http://67-72chevytrucks.com/vboard/s...d.php?t=598758 Last edited by jus2qwk; 09-20-2013 at 03:40 PM. |
09-20-2013, 03:30 PM | #11 |
09-20-2013, 03:32 PM | #12 |
Engine and tail pipes.... not sure Im gonna leave them like that...I may run them to the bumper and turn them down
09-21-2013, 08:24 PM | #13 |
Boy that balancer did a lot of damage. It makes me think I better look at mine. Did it give you any reason it might be going out? I have not cranked up my 4 bolt 350 yet. I rebuilted the 350 but used the old balancer. Just thought I would ask. Did it do any damage to the enging?
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
09-22-2013, 09:36 PM | #14 |
Nope, no warning at all. it was a new stock balancer when I built the first engine and I used it on the new 406 which has quite a bit more power than the old one. I guess it just wasn't up to the task of spinning 6500 rpm's. Any engine I build for now on will have a good high performance balancer on it.
09-25-2013, 08:43 PM | #15 |
made a little bit of progress this week. I got the rear end and back half of the frame cleaned and painted, the new track bar installed and rear centered. Some of the sheet metal hung for final alignment and tweets before paint.
09-25-2013, 08:47 PM | #16 |
09-25-2013, 08:48 PM | #17 |
looks good
09-25-2013, 08:51 PM | #18 |
one more of the cleaned up engine bay... little dirty and once I get the truck together Ill be able to hide some of the wires in the wheel wells
09-25-2013, 08:52 PM | #19 |
