Best suspension lift company?
Who makes the best 4" -6" suspension lift?? And why is it better than the others... the reason i ask is, i just purchased a stock 1985 1 ton long box frame. with dana 60's and 14bolt f.f. im looking to start my frame restoration and dropping my 1 ton 2wd on to it.. i have a 1991 cummins 6bt. i plan on doing a build thread in the spring..
It followed me home?
Re: Best suspension lift company?
I've always run tuff country ez rides, they ride great.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 02-11-2013 at 07:31 PM. |
I have a pro comp 6" on my 85 K10. The springs are a little firm, but it doesn't get too much off road action, just some mud here and then.
Here's my 85: ![]() |
tuff country hands down
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
anybody tried skyjacker's softride leaf springs? i always wondered if it really was a softride
what about off road design's kit?
Rancho has the best springs IMO. they have good sliders between the leaves, the ends are tapered in thickness and width. i run the 76-87 K30 front spring on my jeep and they are really well behaved. i think they are only 2.5" though.
i have some tuff country on my 72 build, and i cant say they are or are not good. they hold the half built truck up well. they are a little rougher in fit and finish than the ranchos, but still have the same features. ryan |
heres a spring rate table to compare
http://coloradok5.com/springratetable.shtml tuff country ez ride 295 lbs...easy winner
I went skyjacker haven't got it finished yet
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
if your puting a cummins in it get the highest rated ones ive ran procomp but have found that the superlift and skyjacker hold up better and the make a fitted spring for added weight witch work well with the cummins and with the weight of a cummins in it should ride well with and of them but might sag after awaile
#13 | |
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
