06-13-2003, 05:42 PM | #1 |
how to replace window felt?
i was messing with mine the other day taking all the old rubber around the doors and felt around the windows and wondered ,how do you get the felt that runs up and down the side of the wing window?...it looks like some sort of a chrome channel inside of the chrome wing window frame,is there a trick to getting this felt out?
06-13-2003, 08:51 PM | #2 |
There are a couple of ways that you can go on the verticle runs. You can buy the strips with the metal channel, drill out the rivets, remove the old one and rivet the new channel in place.
The felt is available, and to replace just the felt, you will need to strip out the old felt using a knife or screwdriver. Once you have the old felt out, you can glue the new felt into place. I use 3M trim adhesive. Either way you will want to pull the vent window assembly out of the door. Jim |
06-13-2003, 10:14 PM | #3 |
oh,ok...thanks Jim....how do you get the vent window out?
06-13-2003, 10:15 PM | #4 |
I replaced my vent window channel felts just last year and used the re-pop style replacement felts. Like a stiff rubber channel with the felt attached. They were like $10-12 at BowTie Bits in Wichita. Pulled, tore, scraped the old felts out and used a wire brush "tooth brush" to clean the channels after making sure all the old was gone and clean metal. I also used the 3M trim adhesive like mentioned in previous reply. Done it with the vent channels removed from the door. Truck was down for re-paint, made it easier. Now the vents look great and window slides and works better. Definetly a recommended re-furbish.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
