Old 02-11-2013, 10:16 PM   #1
SnowNeck
SnowNeck's Avatar
Lift Kit ideas/options/suggestions
I have a 1985 GMC high sierra step side.(short bed) right now im running 33/12.5/15 on stock set up. no rubbing at all no matter what. the high sierras came with a factory 2 inch lift back in the day. but my leafs a really worn out and i thought why not just get a 4 inch full suspension lift off rough country seems like a good idea at least and real cheap like $450 i believe. anyone ever ran rough country? im not looking for anything over a 6 for right now. its my daily driver during the week but hits the trails an mud holes on the weekend.
1985 High Sierra step side 4x4
SnowNeck is offline   Reply With Quote
Old 02-12-2013, 04:44 PM   #2
Duster
Duster's Avatar
Re: Lift Kit ideas/options/suggestions
I would put 2.5 procomp springs in the front and blocks in the rear or rough country (I think they make a 3" or something). That looks the best with a 33.12.50 tire. 4 inch looks best with a 35" tire.
Duster is offline   Reply With Quote
Old 02-12-2013, 05:18 PM   #3
riz
I say go with a 4" suspension and later you may want to upgrade to 35" tires but in the meantime your 33s will still look good.
RIZ
riz is offline   Reply With Quote
Old 02-12-2013, 07:37 PM   #4
82ccshorty
82ccshorty's Avatar
Go skyjacker or tough country. Rough county is cheap but not as good either.
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 02-12-2013, 08:39 PM   #5
SnowNeck
SnowNeck's Avatar
like i said my truck came stock with a 2 inch lift might be a 3 i clear 33's with ease and could put 35's with minor rub. it was part of the high sierra package. but yeah i believe a 4 inch lift is in my future
Old 02-12-2013, 08:56 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
never heard of a high sierra coming with factory lift kit
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 02-12-2013, 09:05 PM   #7
Nin92
Nin92's Avatar
I actually have the 4" RC lift on my truck. Nice and cheap too. New springs up front and blocks in the rear. The back was lower than the front but I would attribute that to the rear springs being worn-out. Rough Country says that you can fit a 35" x 12.50" with there lift but I squeezed some 35" x 13.50" and never had a problem with rubbing.
Here's the truck with the 4" RC
Nin92 is offline   Reply With Quote
Old 02-13-2013, 12:23 AM   #8
Duster
Duster's Avatar
Yeah, me neither. Need some pictures.
Old 02-13-2013, 12:25 AM   #9
Your41Plague12
Your41Plague12's Avatar
Agreed. High Sierra was just a trim package. There were lots of 2-wheel drive high sierras as well, none of which came with blocks. If your truck has blocks, they're aftermarket.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 02-16-2013, 12:39 AM   #10
SnowNeck
SnowNeck's Avatar
it was an option from the factory.
Old 02-16-2013, 12:47 AM   #11
SnowNeck
SnowNeck's Avatar
I was surprised hear myself. I was doing a lil research on the high sierra and came across it but heres a picture, on 33/12.5/15 my leafs are almost flat in the rear and reversed pretty much in the front. They've seen their day.
Old 02-16-2013, 12:50 AM   #12
SnowNeck
SnowNeck's Avatar
So ya'll would suggest Rough Country?
Old 02-16-2013, 12:57 AM   #13
Nin92
Nin92's Avatar
I think you'd be more than pleased with it, especially if your current springs are worn out. They're pretty quick shipping it too.
Old 02-16-2013, 12:59 AM   #14
SnowNeck
SnowNeck's Avatar
Alright, thank you for the feedback!.
Old 02-16-2013, 09:08 AM   #15
88Jimmy4x4
88Jimmy4x4's Avatar
no it wasnt
front leafs have a neg arch from factory
no....tuff country
1991 GMC Jimmy 4x4
Old 02-16-2013, 12:00 PM   #16
79Betty
79Betty's Avatar
I have a rough country. And when they say rough it really means it. I swapped those for a tuff country e-z 4" lift and loved it. Runnin 35x12.50 15's and never rub. I traded straight up for it so idk about cost though
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 02-16-2013, 01:04 PM   #17
guitarfreak235
guitarfreak235's Avatar
if its your daily driver i wouldnt suggest rough country cuz theyre so stiff. also blocks are kinda the cheap way out the best lift is a true spring lift
2 inch add a leaf, bilstein 5100 shocks, 33" hankook dynapro mt's, flowtech headers true duals and terminator mufflers, 35w and 55w 6k hid headlights, 35w 3k foglights, complete led conversion, 2 kicker cvt 12's, soundstream rub5.800 amp, soundstream speakers
guitarfreak235 is offline   Reply With Quote
Old 02-16-2013, 08:08 PM   #18
Duster
Duster's Avatar
If you think your truck has 2 inches of lift on it now, then when you see it with 4 inches of true lift on it you are going to say, "holy crap those tires look small" And you will swear it is 6 inches, because your truck looks to be at factory ride height to me. I can't find a picture of my old one or I would show you. You can fit a 33.12.50 in a 10inch wide wheel when you run a 2.5 inch spring. Yours has 15x7's and they looked stuffed. I could be completely wrong. Someone correct me if I am wrong.
Old 02-16-2013, 09:55 PM   #19
88Jimmy4x4
88Jimmy4x4's Avatar
your not wrong
1991 GMC Jimmy 4x4
Old 02-16-2013, 10:08 PM   #20
SnowNeck
SnowNeck's Avatar
makes sense, and if i still lived back on the farm id buy a 6 inch and 35s all day. but as a daily driver driving 40 miles a day i just cant. pockets arnt deep enough. They really arnt that stuffed. ive personally seen alot worse. The 4 inch would give me a lil extra flex/clearance, and new leafs. and correct me if im wrong again, but wouldn't getting different dampeners make a difference on the ride on the road? Also I'm trying to do all this while still in high school. so if i get a bad lift kit... im stuck with it for a while. Thanks for all of the feedback.
Old 02-16-2013, 10:20 PM   #21
SnowNeck
SnowNeck's Avatar
Tough country doesnt make a lift for my year of truck, i know i can just leafs separately. There going to be more than double rough countries whole kit, that includes brake lines transfer case drop steering stabilizer shocks... i cant go tuff country 4 inch. maybe one day. but thank you for the suggestion.
Old 02-17-2013, 10:06 AM   #22
88Jimmy4x4
88Jimmy4x4's Avatar
wrong
http://www.suspensionconnection.com/...on/147104.html
then save your money till you can buy a good lift kit
1991 GMC Jimmy 4x4
Old 02-19-2013, 09:56 PM   #23
SnowNeck
SnowNeck's Avatar
wrong
Brings me back then, Blocks or leafs? ( with that tuff country lift )
Old 02-19-2013, 10:58 PM   #24
88Jimmy4x4
88Jimmy4x4's Avatar
blocks in rear on a small lift is fine
Heres my Jimmy with tuff country 3" lift and true sized 33x13.50x15 on 15x8 wheels for reference
1991 GMC Jimmy 4x4
Old 02-20-2013, 02:11 PM   #25
bohmankid
bohmankid's Avatar
That's a great looking rig, 88Jimmy
bohmankid is offline   Reply With Quote
