![]() Join Date: Oct 2005
Farm K20
Ok ..I bought this truck from South Dakotah..The Farmer said he could not take pics cause he was a degenerate..Those were his words..I am in Florida and have not seen it yet...What can you tell from one pic????
Rust Dents Beat up bad No bumpers clearance lights Newer wheels and tires no antenna door button pushed in some chrome left must be some lift camper style mirror rust....
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
Man of Mini-Talents
Re: Farm K20
It has a slider window and it's thrilled to know its going to Florida.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
Currently Blazerless
Re: Farm K20
It does look like it has a lift but if you look close at the front springs they look to have a negative arch like the 73 on up springs. Rear tires don't look centered in the wheel openings, are you sure it hasn't had a frame swap?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Re: Farm K20
Has rust in some really bad spots ( rear wheel arch ), rear bumper seems to be pushed in just a little.
If you gave less than a thousand, at least you a have a decent base to build a new one. I feel sorry for these old trucks and wouldn't hesitate to buy one I liked. John
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
Re: Farm K20
it sure looks to me like there is a body lift on it. look at the gap under the bed and the front fender wells
Re: Farm K20
Thanks to Vintage Windmalls for getting this delivered,,this thing is sitting at my farm now...I had my friend take some pics..It is worse than I thought...
Re: Farm K20
What the hell happened to that thing? How did the frame even get like that in the back?!!! But you can definatly see the body lift....
Posted via Mobile Device |
Man of Mini-Talents
Re: Farm K20
The PO was a degenerate alright. I bet that back frame rail got bent trying to pull a tree stump out.
Re: Farm K20
I had the farmer read me the spid options..He did not bother to tell me he cut a hole in the glove box door for some reason....
![]() Join Date: Jan 2001
Re: Farm K20
If you decide to make the bed into a trailer, you've already got a V notch in the frame. Too bad it's on the wrong end.
Man of Mini-Talents
Re: Farm K20
Looks like a CB was mounted there. The hole was to clear the knobs?
The patchwork on the floors is, um, creative.
Re: Farm K20
The Good...It does run and drive(supposedly)...the wheels(not sure what they are from)
The Bad...The rust,the patchwork,the hole in the glove box door(c.b.)the lift is a homemade job(not good)..no bumpers(appear to have been ripped off) Not sure if it has been body swapped or just sagging leafs...Any other ideas??
#13 | |
Re: Farm K20
The wheel is a GM 2500 wheel used 2007-2010 .
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 Last edited by CrewCab59; 02-12-2013 at 04:50 PM. |
#14 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Farm K20
I hope you got the key for those locking lug nuts. Otherwise you've got some work cut out for you to get all 32 of them off.
#15 |
Re: Farm K20
You gotta know its in rough shape coming from the rust capital of the world
#16 |
Re: Farm K20
No one has mentioned those neat "extra" heater hoses running in to the cowl... that thing in the glove box... extra heater core? Grilled cheese sandwich maker?
Josh '70 Custom Camper / 20 |
#17 |
Re: Farm K20
Looks like a big torx to me.
#18 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Farm K20
A 1/2" extension usually works in these pretty well.
Man the old truck is rough, but I've definitely seen much worse. What are the plans for it Jeremy?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#19 |
Re: Farm K20
Where the heck is South Dakotah? Is it west of Minnesotah?
The truck has certainly worked a few days in its life. Nothing that can't be fixed or replaced.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#20 |
Re: Farm K20
Thanks for the responses..Bought from South Dakota,sorry no offense,,My gym is called Dakotah...As long as this is a true 72 3/4 4x4,this will be my next project...I will use it on the farm for awhile first..
#21 |
Re: Farm K20
I was not offended, I should have put a smily up.
I was going to type that 3/4 ton 4x4's are tough to find, but then I read your signature! ![]() If you find anything else in SD and it's close to me let me know before you buy it, I would gladly check it out.
#22 |
Vintage 4x4s
Re: Farm K20
Jeremy, it was also interesting when I went to pick it up. I called the guy a few days before and told him it would be saturday and he said ok. I then called on saturday am to let him know I was on my way. I got there and his parents then started hastily unloading old metal toys from the bed but leaving the rubbish in there of course. I did throw a bunch of old jugs and trash out of there for you but there was too much for my containers. So, it was even worse when I saw it
![]() I didn't try to run it since the battery was dead and I have a winch. My uncle and i were trying to figure out how they did that to the rear bumper and the only thing we could figure is a payloader with a big chain or a big a** tractor The good news is its a true K20 and everything looks correct about the running gear and chassis (when I was underneath it), however i didn't check the numbers on the frame since you were already committed. Believe it or not it just has light surface rust on the frame. It has a hackjob body lift on it but I believe its the original body and SPID. I was also dumbfounded by the hole in the glovebox door and figure its for a heater. The front frame horn is torn a little on the passenger side and the rear is bent some. All this can be fixed. I can help you weld and straighten it this summer if you want to swing by my place. I still think you did ok since you know authentic K20's with clean titles are hard to find.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#23 | |
Vintage 4x4s
Re: Farm K20
![]() Actually the western MN and Dakota trucks usually aren't too bad. The frame on this truck just has light rust. Eastern MN, wisconsin and eastern midwest seem to use more salt but there are still good trucks here that have been imported or resided on the farms. I've got examples that have less rust than some southern trucks and on the other hand I've got a 72K20 that has a frame about half its original thickness due to rust that came from wisconsin. It sat in a warm garage every night while each days salt brine ate into it. Now its really only good for other parts.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 02-13-2013 at 02:06 AM. |
#24 |
Re: Farm K20
Thanks again Jud,,,I took a chance on this one..The title,vin plate,spid,frame,is all I was after,,Everything else will be replaced..Since the farmer said his brother bought this in 74 he thought it was original, they relaced the motor a few years ago and rebuilt tranny last year..Beat up but all there...
#25 |
Vintage 4x4s
Re: Farm K20
Jeremy, I figured you had a total body replacement in mind. This will be good for that. By the way, what looks like part of the frame sticking out the back is just the inner part of the bumper. The rear of frame is still bent but its not kinked that bad.
