Old 02-12-2013, 12:17 AM   #1
rs74
rs74's Avatar
Lets see how your exhaust is run.
I am looking ahead in the build and starting to look at pypes exhaust. Right now my thoughts with the exhaust focus on the trans crossmember. I way mine was run on the short bed was one side exhaust ran under the crossmember and the other side ran over. If I go with a x-pipe then I would rather run up and over the crossmember. I am not sure if that can be done with the stock crossmember. I haven't looked into it that much yet. But if you have any photos of how yours is run by the crossmember. I will be running full length headers, 2.5" pipe possibly with x-pipe and pypesor magnaflow mufflers.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-12-2013, 12:30 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Lets see how your exhaust is run.
I have a pypes x pipe with one over one under full length headers. I jus bought the universal kit and welded it myself along with a U mandrel bend that I used to make the s bend over the crossmember on the drivers side.
I used the clamps to get everything in place and held together. Then pulled it off as one piece and welded it up
I like pypes stuff family's been using it for years great value and some decent metal
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-12-2013, 12:35 AM   #3
rs74
rs74's Avatar
With the x-pipe I am not sure I like it one over and one under and being fully welded. If I need to take the crossmember down I don't want to have to mess with exhaust. Is there not a way to run them both either on top of or below crossmember the x-pipe.
Roy
1987 R10 shortie
Old 02-12-2013, 10:59 AM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Someone posted a link to an aftermarket tubular crossmember once. It looked nice but I don't recall if it made room for a straight shot out of the headers.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-12-2013, 04:30 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
member mooseknuckles has one
http://67-72chevytrucks.com/vboard/s...415628&page=10
post 1101
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-12-2013, 05:04 PM   #6
chevy-fun
chevy-fun's Avatar
brp hotrod makes a nice one but only sold as a lsx conversion kit. wish they sold the crossmemeber only.
chevy-fun is offline   Reply With Quote
Old 02-12-2013, 05:06 PM   #7
rs74
rs74's Avatar
Do you have a pic that you can post. Thanks
Roy
1987 R10 shortie
Old 02-12-2013, 07:22 PM   #8
68Timber
68Timber's Avatar
post 1101
Thanks John. That looks pretty simple. The frame is boxed there on his truck, but with it being straight across I don't see why you couldn't make the same thing at home. Just have to be careful to set the angle right, but straight across would be easy.
John
74 Honda Z50 build
Old 02-12-2013, 08:17 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Yup,looks straight in out,sure is a sweet setup
John
Old 02-12-2013, 09:47 PM   #10
rollin thunder
rollin thunder's Avatar
How about side pipes? don`t have to worry about any crossmember issues there haha
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 02-12-2013, 09:51 PM   #11
INSIDIOUS '86
Long tubes exit to close to both go over. However the crossmember doesn't interfere with the way it mounts. You can simply slide it out from over the exhaust
You can however take cut two Halfs of two cross remembers and make a double hump one.
I will get a pic as soon as possible
Old 02-12-2013, 09:54 PM   #12
INSIDIOUS '86
Old 02-12-2013, 10:15 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
Nope!
John
Old 02-12-2013, 10:17 PM   #14
Brad18xx
look at page 3 post #63 on the bad karma build this should help you out http://67-72chevytrucks.com/vboard/s...=421206&page=3
Brad18xx is offline   Reply With Quote
Old 02-12-2013, 10:24 PM   #15
TwinTurbo
TwinTurbo's Avatar
TwinTurbo is offline   Reply With Quote
