Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-12-2013, 12:49 AM   #1
TexasSteve
TexasSteve's Avatar
Double DIN in 2002 Sierra?
I've seen one on a 2001 Tahoe but couldn't get any install info on it. The dash trim opening appears to be big enough for a double din face but Scosche only makes a single din adapter. But Metra does make a double din adapter.
So what is the story here? Will a double din fit in my 2002 GMC Sierra or not?
TexasSteve is offline   Reply With Quote
Old 02-12-2013, 12:31 PM   #2
SamMargritz00
SamMargritz00's Avatar
Re: Double DIN in 2002 Sierra?
NOOOO. You have to do some modding. One way is to cut the dash bezel and make it bigger and use fiberglass and repaint it. the easier way which I did this install on my brothers 99 silverado I had to change up a bunch of stuff. The factory radio is like a 1.5 din, so what you have to do is buy a dash bezel from like a 2005 or similar. Then you have to buy a rado trey from that same year. I had to mod it a little bit but it works fine. then the last step is to move the fan controls down a little bit and bring it out a little bit as well. I just made wood spacers for that. If you want pictures I can get them for you if needed. Hope this helps and not confuse you any more haha.
-Sam
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399
SamMargritz00 is offline   Reply With Quote
Old 02-12-2013, 12:57 PM   #3
jimmydean
jimmydean's Avatar
You can make anything fit with a Dremel and some fab skills.
If they make an install kit, it might work. I just bought a '92 Silverado with the gawd awful dash install that I will either remove or redo.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-12-2013, 09:03 PM   #4
TexasSteve
TexasSteve's Avatar
The radio face opening is bigger than the specs show for double din faces, which tells me it'll fit plus the Amazon listing of a double din mount.
But then if you look at the Mertra website, they don't list a double din mount for a 2002 Sierra. A wrong Amazon listing wouldn't surprise me, but the face opening in my dash is, as measured by me & my tape measure, bigger than double din listings dimensions.
So I dunno what to think without buying everything & trying but don't like dealing with Returns.
Old 02-12-2013, 09:23 PM   #5
SamMargritz00
hmmm......I don't know then. I was always led to believe the 99 dash and 02 dash were the same. I've been wrong before.
Old 02-12-2013, 10:56 PM   #6
SamMargritz00
Here's pics of my brothers 99
Old 02-12-2013, 11:00 PM   #7
TexasSteve
TexasSteve's Avatar
Details please!
What mounting kit? Any mods or direct bolt-in after a mounting kit was installed?
I do see what appears to be a small gap at the bottom of the AC controls. Did he use the later model dash surround piece (which i think is bigger)?
Old 02-12-2013, 11:11 PM   #8
MadManAndrew
The stock opening is not big enough, however, it can get there with very little trimming. I used a kit from thedetailss.com and I loved it. Here's my thread.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 02-12-2013, 11:17 PM   #9
TexasSteve
TexasSteve's Avatar
Thanks! That is the way I'm definitely going now.
Old 02-12-2013, 11:18 PM   #10
SamMargritz00
No kit just used newer style pieces.
http://pages.ebay.com/motors/link/?n...d=271155597071
Here's a link of what two pieces you need to buy. Even on some ebay listings for the bezel it'll say in the subscription that it fits 99-02 for double din install. I'm on my phone right now but ill get you a complete writeup when I'm on my computer tonight or tomorrow.
Old 02-12-2013, 11:33 PM   #11
TexasSteve
TexasSteve's Avatar
I read a link the other day, mighta been yours....the name rings a bell, and while it does look pretty good? I wanted to avoid having to replace the whole dash surround & make as many cuts & trims inside as what I saw in the thread. I don't mind modding to get what I want, but my days of modding are getting behind me now. I am more into direct fits with minimal work nowadays.
I can respect those that mod to the nth degree to get what "isn't possible" to be possible, but it is beyond my abilities these days.
Old 02-13-2013, 12:11 AM   #12
SamMargritz00
There's really no cutting or hacking which is why I went that way, his original bezel had the dark wood grain on it and didn't want to mess it up. Old bezel snaps off, unscrewed the old radio trey, new one needed trimed a little bit, put radio in, made spacers for fan controls, then snapped new bezel in place. Not the "custom" look that I love but this made it look close to factory.
Old 02-13-2013, 12:55 AM   #13
TexasSteve
TexasSteve's Avatar
Probably not the thread I read then. It talked about eliminating the flip-up door for the cig plugs & having to cut the ashtray slide-out to clear the newer model bezel.
Old 02-13-2013, 06:11 AM   #14
SamMargritz00
Nahhh, it doesn't open all the way no but still accessable. Idk, I'm not trying to tell you one way is better! Haha, just trying to lend a hand, I didn't want to do much cutting and glassing which made me choose this way of doing it. good luck!!
