02-12-2013, 06:31 AM | #1 |
coys and backspacing issues
can you solve my backspacing questions im looking for rims for my 67 short fleet but im havin backspacing fears i have cpp spindles with 2.5 drop and 1.5 drop springs (4/6) big brake kit and the original 67 rearend adjustable trac bar i would like 20x10s out back and 8.5s up front and have the grinding issues been resolved with these rims or would that not be an issue for me having the cpp spindles i have aftermarket moser axles also so would i have to run a rear spacer or not
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. oldno7 |
02-12-2013, 10:01 AM | #2 |
67-72 parts collector,…
Re: coys and backspacing issues
I assume you are talking about the C-5 wheels from Coys?
These would be my choice: 20x8.5 with a 5.25" BS. 20x10 with a 5" BS. The problem,... is getting Coys to send you what you order.
02-12-2013, 03:11 PM | #3 |
The rotor grinding is minor really. its just a matter of beveling the end near the dustcap. It is only an issue with the HD rotors. Could be solved by using a space on the centercap, but I chose not to go that route. Doesn't take but a few minutes.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
02-12-2013, 03:48 PM | #4 |
Does anybody have pics of 18x8 and 20x10 coy c5's on there 67-72 c-10's??? Thanks
Posted via Mobile Device |
02-12-2013, 06:21 PM | #5 |
If you go with 15's, be prepared to grind on your lower control arm, or have the tubular style, I went with them because they had them on sale, but damn it was a pain. Go with 17's or 20's. just my .02
70 Chevy C10, LT1, T5, "Blue Beast" |
02-12-2013, 06:45 PM | #6 |
Junior Member
here is mine on 18x8 and 20x10 but the drop is photoshopped
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-12-2013, 06:49 PM | #7 |
BB72CHEVKT What backspace are your wheels, I like the wide "lip" in the back. Also what tire size did you go with??? Thanks JEH
02-13-2013, 12:51 PM | #8 |
just wanted to say thx for replys i need to do a little more research if pos could you al put up pics of your coys and boss rims with measurments n tire sizes
02-13-2013, 05:06 PM | #9 |
Junior Member
I am not sure I bought them off board member PainterD.
