Old 06-13-2003, 06:32 PM   #1
Chevy Punk
Fuel pump question?
Hey guys, I was wondering if you could help me with something. I bought a new fuel pump for the '75 350 that I put in my truck and it has three fittings on it. One is the inlet from the gas tank and one is the outlet to the carb. There is one other one that is in between the two and looks like the inlet but is about half the diameter of it. What is this for? as far as i can see there is nothing down there to hook it up to. Maybe I have the wrong fuel pump? BTW it is in my 71 Chevy that had a 350 in it. Thanks for the help.
Chevy Punk is offline   Reply With Quote
Old 06-13-2003, 07:18 PM   #2
ddsmith
Glowing since 1978
ddsmith's Avatar
I'm pretty sure that is a fuel return line to the tank. I think they installed fuel return lines to the tank to prevent vapor lock problems on some vehicles. As long as the gas was flowing somewhere like back to the tank it wouldn't heat up as much preventing so many vapor lock problems. I would check with the auto part store. The pump probably belongs on some other vehicle or the pump manufacture decided that the pump is the same as yours without addressing the port you speak of.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 06-13-2003, 07:27 PM   #3
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Go buy one for your year of truck, not the year of the engine. That's for the overflow/return in newer trucks with the smog control stuff.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 06-13-2003, 07:50 PM   #4
cojnit
Nothing clever
cojnit's Avatar
that sounds like the one for the '76 3/4 that I had. I think the 76 year was the year they changes all of the smog junk
cojnit is offline   Reply With Quote
Old 06-13-2003, 08:49 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And if you are unable to return it, a short hose with a bolt clamped in it with some RTV (fuel safe of corse) will solve any problems with it.
I agree with returning it and getting one for the 71 truck regardless of the engine year.
Old 06-13-2003, 10:28 PM   #6
Chevy Punk
Thanks for the replies. Will there be any problems with plugging the return line? Does it have any pressure or vacuum from it that could cause the fuel pump or plug to fail? If not I think I will do that.
Old 06-14-2003, 11:07 AM   #7
Project1970
14.1 @ 96MPH
Project1970's Avatar
I've actually heard that plugging return lines on some pumps like that causes the fuel pressure to go too high for a carb...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 06-15-2003, 12:33 AM   #8
Longhorn Man
Really?
I retract my statement, after thinking about it that does make plenty of sence.
