02-12-2013, 11:15 AM | #1 |
Making own Brake lines
This would be for a 74 chevy brake setup if that makes a difference. Need to know what to look for in flare tools to make custom lengths.
Thanks in advance. |
02-12-2013, 08:00 PM | #2 |
67-72 parts collector,…
Re: Making own Brake lines
But the best bender and flaring tool that you can afford.
Eastwood usually has some good tools.
02-12-2013, 09:11 PM | #3 |
Man of Mini-Talents
I would recommend using regular steel or copper/nickel lines because they are much easier to work with than stainless.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-12-2013, 10:20 PM | #4 |
I guess the question is more of a what degree flares will I need?
Posted via Mobile Device |
02-14-2013, 02:23 AM | #5 |
45 degree inverted flare. Unless you are building some high end piece I would stay away from 37 degree single flare AN tube fittings on brake lines. You can still use AN steelbraded brake hoses with adapters to 3/8-24 inverted flare (45)
Posted via Mobile Device 3/16 steel as Keith said not stainless unless you have (or get) a $200+ snap on flairing tool. Stainless will eat craftsman's best for lunch. |
