![]() Join Date: Dec 2004
WTB transfercase bolts
I am needing the 2 bolts that bolt the side frame bracket to the side of the transfercase,,i have no clue where i put mine at,,i could just go and get some if i new what size they were,but i dont even have any bolts close enough to fit,,if anyone has a couple i would appreiciate it
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
Re: WTB transfercase bolts
it is a np205 out of a 70 jimmy if that helps
surely someone is parting out a 4x4 somewhere
![]() Join Date: Jul 2001
Might want to reconsider those bolts. Seems the general opinion on the 4x4 forum is you are better to leave them off. Several mention that using the bolts and brace makes the drive train to rigid with no flex and the adapter between the transfer and transmission cracks. Just passing on some 4x4 reading I did.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
really...i hadnt heard that...so they crack with the adapter for the 4l60e or just any adapter
The transfer case I have in my '67 k10 doent even have the threaded holes for the frame mount. Its a np205 transfer but not sure what its out of. Havent had any problems thus far.
#7 | |
Randall Cowboy the 70' Crew Cab The DUKE K50 Crew Cab 2nd gen build thread Drill Sergeant The Ponderosa |
well by golly, i guess i will just not use it then,,,ya learn something new everyday
So yall are leaving off the entire side support mount? Or is that just with the upgraded trans?
I have factory th350 NP205 and I kept my side bracket on? Figured it was there, it must have a purpose. Explain please!
1967 SWB C-10 1972 Blazer 4x4 2011 Silverado |
