Old 02-12-2013, 01:48 PM   #1
budnikguy
budnikguy's Avatar
1967 C20 3/4 Rolling Chassis - $175
67 GMC 3/4 Long bed rolling chassis, 4.10 gears with a posi, all original. Does need the drivers side rear upper shock mount welded. Was a driver up to a year and a half ago. Surface rust only!! Open to trades also..
Adam
951-544-0721
budnikguy is offline   Reply With Quote
Old 02-12-2013, 02:00 PM   #2
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: 1967 C20 3/4 Rolling Chassis - $175
Quite a collection you have in the background. Good luck with the sale.
I recently picked up a 3/4 ton that has no engine/tranny/driveshaft. Everything else I have is 1/2 ton. Do you know if the drive shaft is the same from a 3/4 to 1/2? I have a 2 piece 1/2 ton driveshaft but was unsure if anything else changed. Both trucks are coil spring longbed models.
Thanks, John
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-13-2013, 11:02 AM   #3
budnikguy
budnikguy's Avatar
Anyone???
Old 02-13-2013, 11:12 AM   #4
nobolt
nobolt's Avatar
i'll get in line for the locker if you part it out...
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 02-13-2013, 01:31 PM   #5
70blackfish
lot of nice stuff in the background......
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 02-14-2013, 03:38 PM   #6
budnikguy
budnikguy's Avatar
hey thanks everyone...back to the top. May look at parting, but that will be a little bit as I am moving and do not want a non roller before then...
Old 03-21-2013, 06:57 PM   #7
budnikguy
budnikguy's Avatar
open to trades...anyone?? Bueller Bueller
