Old 02-12-2013, 02:01 PM   #1
sjarrett71
sjarrett71's Avatar
Pulley Mixup
The power steering pulley I have on my pump is flat and it appears I needed a crank pulley that is cast like the one in this picture:
I have the three groove crank pulley and would like to change my power steering pump pulley to one like the offset one in this photo:
My question is this....Are the ones you can buy in the aftermarket the same as the one in the second pic and do they mount the same, with the keyway and nut on the outside or do they press on?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 02-12-2013, 06:14 PM   #2
First c10
First c10's Avatar
Re: Pulley Mixup
Scott
I just pulled mine off and blasted and painted them brackets and pulleys. The pump and bracket you have and flat pulley with the key way and nut is what I have. I have a 4 pulley crank pulley and it uses the outer one. .
Outer one for p/s
2nd not used
3rd a/c
4th or closest to the motor. Alternator.
Hope this helps.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-03-2013, 07:44 AM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Pulley Mixup
Can you get the number from the pulley in that second picture? I bought a reman p/s pump and my old pump used a press-on pulley but this pump has the threaded shaft and my old pulley will not work. I need a pulley that is like the one in that second pic.
Thanks,
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-03-2013, 10:37 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Pulley Mixup
Trying to match these parts is difficult unless you're lucky. There's been many parts swapped and configurations changed in the last 40 plus years. Best thing is to get all the parts from a completely stock engine otherwise you will have to do some tweaking, adding spacers and maybe fabricating brackts.
I always tell anyone that's converting to p.s. to get everything from the water pump and harmonic balancer forward. In other words all the pulleys, belts, alternator, fan pulley and all mounting brackets off the donor engine (if at all possible). Even if the parts are bent, rusted or unusable they can be used to match to newer ones.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 05-03-2013, 12:10 PM   #5
70STOVEBOLT
Re: Pulley Mixup
I have all the correct brackets and all the other pulleys line up ok. The p/s pump that I had before is basically the same as the one I have now, except the type of pulley it uses.
Now I just need a pulley with the correct offset for a threaded shaft type pump.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
