Old 02-12-2013, 02:28 PM   #1
wayno
How remove wiring plugs from firewall
Starting to clean up the firewall during my cab off restoration. Is there a trick to removing these successfully? I've attempted to force the softer rubber around the outer most edge back through the hole but it doesn't have a whole lot of give to it. Help?
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 02-12-2013, 02:35 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: How remove wiring plugs from firewall
The ignition wire plug has a bevel to it you need to push the harness inside towards the glovebox first then pry out the grommet. The heater wire grommet should not be that difficult to push out.
Old 02-12-2013, 02:45 PM   #3
wayno
ah... so they are two pieces? Does the grommet come off from the inside or the out?
Old 02-12-2013, 03:11 PM   #4
aerotruk63
aerotruk63's Avatar
I'm over 50, cant remember. If memory serves me towards the inside of the cab.
Old 02-12-2013, 05:03 PM   #5
Bret B
Just pulled mine out last week. The plugs are held in with semi-hard rubber grommets. I pushed the edges in from outside to inside and worked around the entire edge before it pushed through. It seemed as though the plug was going to break or get damaged, but it just took a little effort and working around the entire edge. Used a flat head screw driver to do the deed. Hope that helps somewhat
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 02-12-2013, 11:39 PM   #6
wayno
Man they are a lot tougher than I thought... put the one on the passenger felt like the entire thing was hard plastic.... I ended up hand sanding around it and taping it off - not wanting to break it off.
Old 02-13-2013, 01:58 AM   #7
padresag
if you can heat them up they become pliable. to put them back just give them a little microwave time
ron
padresag is offline   Reply With Quote
Old 02-13-2013, 09:16 AM   #8
luvbowties
luvbowties's Avatar
Question Re: How remove wiring plugs from firewall
ron
...and if we use only a microwave, will male chauvinists still call us a sissy?...
Good tip, btw!
s
luvbowties is offline   Reply With Quote
Old 02-14-2013, 12:50 AM   #9
Captainfab
60-66 Nut
I have found that sometimes a little silicone spray helps make them slippery enough to get them out of the firewall.
Old 02-14-2013, 12:57 AM   #10
Reyals Bemus
Yea they get hard as a rock after nearly 50 years.
Reyals Bemus is offline   Reply With Quote
