02-12-2013, 04:32 PM | #1 |
What bulb goes in the heater controls light socket?
My light bulb is missing from the heater controls. I unplugged the grey wire that leads to the socket only to find it empty.
Its different then the dash size. Thanks!
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! |
02-12-2013, 04:40 PM | #2 |
Re: What bulb goes in the heater controls light socket?
Joe,
I am working on my heater too, can't help on bulb size right now ! But will pull bulb and get # for you! Life good on a island ? Posted via Mobile Device
71 C-20 07 Magnum RT AWD |
02-12-2013, 05:23 PM | #3 |
02-12-2013, 05:39 PM | #4 |
Awesome thanks!
02-12-2013, 06:15 PM | #5 |
My pleasure! Truck is here at work, only too a second!
02-12-2013, 06:54 PM | #6 |
Cool Truck
I need one too, thanks for the info
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
09-12-2017, 11:12 PM | #7 | |
Posted via Mobile Device |
09-13-2017, 11:28 AM | #8 | |
The Older Generation
Should be able to get one at any auto parts store or salvage yard. (out of an older vehicle) Manes truck parts would have it also. (8100 State Hwy WW, Odessa, MO 64076) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-13-2017 at 11:41 AM. |
09-13-2017, 06:52 PM | #9 | |
09-13-2017, 10:21 PM | #10 | |
Wow! I know they have a lot of stuff on hand, or did the last time I was there. You also have Classic Parts in the Riverside area. (out by the Argosy Casino) LockDoc
09-14-2017, 04:50 AM | #11 |
WadmalawJoe,
I may have one, you are welcome to it. When i get home Sat. I will look and see. If I do you can have it. I will let you know through PM. |
09-14-2017, 05:32 PM | #12 |
Thanks Wadmalaw Joe, I look forward to hearing from you.
05-16-2018, 10:39 AM | #13 |
I found that BA9S style bulbs fit and work. They make LED ones too.
Trouble I'm having is my bulbs burn out after 20 min of installing them? Should I be using something other than 12v? Is there a resistor somewhere? Not that I need the light, but it's there so I'd like to have it work. |
05-18-2018, 07:56 AM | #14 |
Old member
06-30-2018, 04:21 PM | #15 |
Does the gray wire head to the fuse box and inserted in “cluster”. I have a gray wire that is cut and my light that goes to heater is cut at base.
06-30-2018, 04:51 PM | #16 | |
Msgt USAF Ret
See the arrows and follow the gray wire
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
06-30-2018, 08:27 PM | #17 |
Thank you VetteVet. I am currently switching my cluster from 3 hole to 7 hole and have read and screen shot several of your conversations. You my friend are invaluable to this site. Thank you for your expertise on these wonderful C10 trucks that we all love.
07-01-2018, 09:51 AM | #18 | |
Msgt USAF Ret
BTW welcome to the forum.
02-03-2023, 07:28 PM | #19 |
resurrecting this post - I have 1445 bulbs (2) of them in my a/c - heater control. Initially I thought I had one burnt out, but upon really close inspection I could (barely) tell it was working! Yes, they are both really dim. The manual shows 1895 bulb, which I know are more watts/lumens and somewhat larger. Do they really throw that much more light to illuminate this control panel?
I'm surprised there are not any photos of dash panel in low light conditions to show the illumination of gauge panel, and of course this control panel. Are people satisfied with their a/c - heater controller with apparently 1895s? Perhaps a change to LEDs? thanks!
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
02-05-2023, 12:13 PM | #20 |
Here's mine. The camera makes it look a lot brighter than I think it is in real life, but you can see how bright the gauges are for comparison. I stuffed another bulb socket in the blank hole on the passenger side of the ac control panel, so I have two working for me. I think it helps a bit, but it's still pretty dim.
1971 Pontiac Firebird 1971 GMC C2500 |
02-05-2023, 06:19 PM | #21 |
The AIR trucks take two bulbs. Heater only, takes one bulb.
02-05-2023, 11:02 PM | #22 | |
thanks, but that's some restomod aftermarket item - does not help me with the question.
02-05-2023, 11:03 PM | #23 |
yes, you're correct. unfortunately this also does not help me wiht the question in search of.
02-06-2023, 01:29 PM | #24 |
I bought a box of 10 #1895 bulbs on Amazon for $6.56 - thought I'd share with local friends if they are in need too.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
02-06-2023, 02:50 PM | #25 | |
I can assure you the other poster and I meant no harm. Could be the chances of the board providing meaningful advice just went down exponentially. Cheers. |
