Old 02-12-2013, 04:39 PM   #1
RANDAL
RANDAL's Avatar
headlight issue
Hey Guys having some trouble with my headlights on my Jimmy. coming home from work last night the passanger low beam headlight went out. It works on the high beams so I'm guessing the bulds low beam went out so I switched them to high on the way home all 4 were working when I left my work but when I got home the high beam light was out (the inside light)and only the low beam bulb was working on high I hope this isnt confusing to anyone. if you can help that would be great.
RANDAL is offline   Reply With Quote
Old 02-12-2013, 10:56 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: headlight issue
Does the floor switch need replacing?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-12-2013, 11:09 PM   #3
Dale99
Re: headlight issue
When my floor switch went out, it would only dim the outers, and not turn on the insides.
I'm thinking a ground wire?
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 02-13-2013, 12:38 AM   #4
RANDAL
RANDAL's Avatar
Re: headlight issue
Thanks for the advice I found out that my bulbs went out low beam burnt out same with the high beam.
