Old 02-12-2013, 06:30 PM   #1
1967chevy-1
Smile Help ID steering column parts
Can anyone help me identify and hopefully locate the two plastic washers inside the upper steering column in my 1967 C10? Does anyone know the correct names of these two washers?
They are shoulder washers, by that I mean they are not flat, but have a flat side attached to a round side and are all one piece. They go above the shifter section and below the turn signal section inside the steering column.
My washers are broken and need to be replaced. It would be great to locate a vendor or store where I could pick up two new ones for my column rebuild.
Any help will be great,
Guy
1967chevy-1 is offline   Reply With Quote
Old 02-12-2013, 09:42 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Help ID steering column parts
ttt
Been a while since I had mine apart but I can't seem to figure out which washers you are talking about. I don't recall two plastic washers like that but then my memory is fuzzy. A pic would help or maybe someone else can give you a response.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-12-2013, 10:39 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Look through the thread below. I came across it while searching for something else. It may help you determine what you have. Problem is I don't know where you can get those parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=471499
06 Trailblazer
