axle to frame measurement?
Does anyone with a wood lwb fleetside know the measurement between the top of the axle and the bottom of the frame? I am going to be making my own panhard bar and mount and would like to know this because my bed is off right now.
Thanks Posted via Mobile Device |
Re: axle to frame measurement?
The reason I cant measure it myself is because there is not the correct amount of weight and I didnt measure before bevause I wasnt planning on doing this. So could someone with their truck parked inside measure this for me?
![]() Join Date: Dec 2012
Make an adjustable one?.....then you can set it for what ever.
Sorry I have leaf springs BTW
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Since the ride height is so dependent on spring rate and condition all anyone could give you would be a close maybe number. Probably do better by simply weighting your rear frame down with the 450 LB difference (rear axle) between a chassis cab and a fleetside. An adjustable bar is a really good idea as well. If you are moving the tank that is also a consideration.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#5 | |
Best of luck buddy.
Thanks guys! I was planning on an adjustable panhard, but I was just gonna use this as a baseline. I will get some feed bags and weigh her down and see where the rear end sits from there.
