brake repair tools
i'm going to redo the brakes on my truck next month. all new calipers, rotors, pads, drums, shoes, brake hoses, MC, power booster.
Am I going to need any special tools to do this? |
![]() Join Date: Feb 2011
Re: brake repair tools
Get your self some of these, money well spent
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
![]() Join Date: Dec 2012
A few things will help.
Brake bleed vacuum pump Line Wrenches Brake spoon Hold down tool/spring tool PATIENCE
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
thanks. I forgot about the bleed kit. I almost bought one on amazon the other day. I saw those hold down tools at the parts store the other day so ill pick them up.
Also one of these to bleed the brakes
whats that thing called? wheres it used? on the bleed screw?
Active Member
![]() Join Date: Jul 2007
Called a brake bleeder wrench and yes it's used on the brake bleed screw.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Yes it is used on bleeder screw, each end is different size.
great thanks guys.
i assume the line wrench / flare nut tools should be SAE?
