Carpe manana
![]() ![]() Join Date: Dec 2010
Aux battery harness install: Where is hole placed in firewall???
Should have asked before painting
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Aux battery harness install: Where is hole placed in firewall???
I went out and took a picture this morning,is this the shot your looking for (red wire)?
Carpe manana
Thank you for the pic!!!
Glad to help.
Carpe manana
Looks like it would be centered in the firewall dimple just below where the tach harness hole would go. Good to know for anyone adding one or both of these options. Pete
Looks like I will be drilling a hole for my tach harness!
![]() Join Date: Jun 2012
Great info there..Now another question is where does the harness connect to inside the cab?
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
Carpe manana
Here's a schematic of the harness if that helps....
Carpe manana
Pic borrowed from another member of the dimples I mentioned with a factory TACH hole. Looks like the hole for the aux battery is centered in the dimple that is second from the bottom whereas the tach hole is centered in the dimple third from the bottom.
What the best way to drill a clean hole for these harnesses?
Posted via Mobile Device |
That works...Thanks Man
