Old 02-13-2013, 01:49 AM   #1
The Grinnin Possum
The Grinnin Possum's Avatar
The Possum build
Well let's see..... searched for about 6 months and finally found a good rust free body and ran like a top. 1972 CST original ochre now red. It ran when I bought it but the steering was SCARY!!!!! So I decided to trailer it back home to Memphis.
Got it home and it would not start, timing had jumped out.
Started the strip down. Seems like the previous owner had an aversion to screws, he would take 8 out and put 3 back in, bonus, makes it a lot easier to take it apart.
As far as rust...... found a spot about the size of a baseball at the bottom of each kick panel. I can hear the angels singing NONE anywhere else.
Plans for the Build
New Motor 420 HP 490ft/lbs 350 SBC
700r4 trans
rebuild front Performance Suspension kit
disc brake rear?
373 gear
33x12.50 tires
4 inch suspension lift
shave tailgate
shave rear hatch
vintage air a/c
The Grinnin Possum is offline   Reply With Quote
Old 02-13-2013, 01:57 AM   #2
The Grinnin Possum
Re: The Possum build
front clip off, loaded to go to shop.
new engine
frame out!!!!
Old 02-13-2013, 11:19 AM   #3
fun in dirt
fun in dirt's Avatar
Looks like you got a great start!
Good to have you on this board...lots of good info & folks here!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-13-2013, 04:30 PM   #4
swyfor5
swyfor5's Avatar
Nice! Lot's of pic's please! Welcome to the board!
swyfor5 is offline   Reply With Quote
Old 02-13-2013, 06:53 PM   #5
RANDAL
RANDAL's Avatar
Welcome from Utah
RANDAL is offline   Reply With Quote
Old 02-26-2013, 10:07 AM   #6
monte0185
monte0185's Avatar
Good Lookin truck!! Welcome From a fellow memphian!!
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 02-26-2013, 04:18 PM   #7
The Grinnin Possum
Performance Suspension kit didn't work out, their ball joints were standard grade and the parts were mixed manufacturers McQuay-Norris and MOOG. so now on the search for quality front end parts. Prefer MADE IN AMERICA.
Rock auto has MOOG, raybestos, and other random manufacturers.
I have also heard good things about the NAPA parts. They have two levels of parts Master ride Chassis series which are the low end and then the NAPA Chassis which look like grade 8 and blue poly bushing and have a lifetime parts warranty (with a lot of exceptions). they say made in America.
"The NAPA Chassis warranty does not cover any loss due to misuse, alteration, accident, abuse, neglect,
normal wear, improper application or installation of the products. This warranty only applies to NAPA Chassis
products installed on passenger cars, vans, and light trucks. It does not apply to products installed on vehicles or
equipment used for the following: towing, racing, public service, security, government, off-highway recreational, offhighway
competition, fleet or commercial purposes, or if used in any aircraft or aviation application. The warranty
does not cover any loss or liability for incidental or consequential damages that may be caused by a breach of this
written warranty."
Old 02-26-2013, 05:28 PM   #8
The Grinnin Possum
Further research the NAPA top grade parts are made by raybestos and are the same as Raybestos pro grade products.
Upper ball joint NAPA 46.46
same Upper ball joint rock auto 29.99
Old 03-04-2013, 04:53 PM   #9
The Grinnin Possum
I'm looking for bolt and screw kits specifically for a blazer. Does anyone make them and who carries them? I looked at the kits at The Fillling Station and talked to one of their techs and he didn't think their were any Blazer kits.
I suppose you could use use a fleetside kit to cover most of the outside but still need all the top parts.
I'm not saying let's go and kill all the stupid people. I'm just saying let's take off all the warning labels and let the problem sort itself out.
