Old 02-13-2013, 12:49 PM   #1
solidaxel
solidaxel's Avatar
Injectors- sensors-Transmission connections
This is for a what I believe to be a 2006 Silverado 5.3 and I am going to place it into a 78 Silverado.
My question is besides the obvious, 8 injectors, 4L60E plug, MAF, Knock, water temp, TAC and peddle, Cam & Crank, what else in needed in the wire harness and computer to complete the wiring on the ECM.
I have looked and did not find a list of sensors to eliminate, like the purge soloniod and others.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-13-2013, 01:11 PM   #2
OldCreek
OldCreek's Avatar
Re: Injectors- sensors-Transmission connections
I usually work from the connectors/fuse box and run backwards towards the engine to determine what I may need to keep. Get the "pinouts" for your year engine so that you know what wires are what. I tape the ends and label them for future use.
Keep the front O2 sensors...you could ditch the rears if no cat conv. I got rid of evap wiring, egr wiring, coolant sensor at radiator, etc....
Some wires will run into the cab for tach, speedo, mil light, cruise, etc...
Better to keep and label now and then finish pulling them out later in case you need them...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
