Old 02-13-2013, 01:31 PM   #1
mrhurt73
steam port line???
i am guessing the line pointed to with the red arrows is steam vent line? maybe. comes off the drivers side head the goes through the throttle body and out to a really long hose.
from the factory im guessing this connected back to the radiator.
what have you hooked this to? do you plug it?
and just for reference my radiator will be higher than block.
My Projects-
http://67-72chevytrucks.com/vboard/s...d.php?t=557301
Quest for Hot Rod Power Tour 2013.
http://67-72chevytrucks.com/vboard/s...d.php?t=543735
my 85 GMC 2wd to 4wd conversion for the wife.
mrhurt73 is offline   Reply With Quote
Old 02-13-2013, 02:37 PM   #2
bohmankid
bohmankid's Avatar
Re: steam port line???
Yes that is the steam line. yes you can just return it to your radiator or radiator hose or water pump. You can bypass the throttle body and just go straight from the head to the radiator (if desired). Read this thread I've attached to get a little more info http://67-72chevytrucks.com/vboard/s...d.php?t=562762
bohmankid is offline   Reply With Quote
Old 02-13-2013, 03:35 PM   #3
mrhurt73
ok, if once you purged the air out, is it needed still?
could you block it off as long as the system was sealed? or is this big no no?
My Projects-
Old 02-13-2013, 03:50 PM   #4
82chevylsx
82chevylsx's Avatar
About 1,070,000,000 results (0.25 seconds)
that's a big no...no.... cause it's the water that run's through your head's so you do need it......or els your motor is going to over heat....
82chevylsx is offline   Reply With Quote
Old 02-13-2013, 05:39 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Ive seen them done both ways, I prefer the steam line t be emptied into the highest point personally.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-13-2013, 09:20 PM   #6
jrdv
jrdv's Avatar
From what I gather, the steam line are important for cold weather starts....help warm up the throttle body. I plan on using the steam line kit from Summit.
John
jrdv is offline   Reply With Quote
Old 02-14-2013, 09:02 AM   #7
Clyde65
Clyde65's Avatar
the steam line is definitely for the TB warm up in colder areas but it also provides an escape for air in your cooling system. if you have a "bubble" in your heads or elsewhere, you run a real risk of overheating. I know some guys swear they never hook them up, but me, I want it hooked up as close to factory as I can. GM didnt put it there just to be pretty ya know?
Clyde65
Rebuild of Clyde
support our troops!
Old 02-14-2013, 11:04 AM   #8
mrhurt73
yeah its not to be pretty, then LM7 is about as ugly as a mud fence.
My Projects-
Old 02-15-2013, 10:03 AM   #9
Clyde65
Clyde65's Avatar
when I replaced my radiator, I poured coolant/water down the upper hose ( my mechanic friend said it was best) it is said to help alleviate the air pockets.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-18-2013, 02:40 PM   #10
Custom 68
Custom 68's Avatar
it has worked for me for several years and a several thousand miles on my swap but they make a "TEE" fitting the right size to splice into your heater hose. That is what I did and no problems that I know of. This is not the highest spot if anything it is the lowest but it works.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-19-2013, 08:13 AM   #11
mrhurt73
well i talked myself into one of these
Flex-a-lite In-Line Radiator Hose Adapters 32082
will install it in the upper hose when it crosses over to enter back into the radiator.
My Projects-
Old 02-19-2013, 12:09 PM   #12
JNJchev77
Registered Cruiser
JNJchev77's Avatar
mrhurt... Take a look at this before you order that flex-a-lite piece
http://www.jagsthatrun.com/Pages/Par...g_LSI-tee.html
This has them steam port fitting and petcock valve already included, and less expensive . This is what I'm using
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 02-20-2013, 11:01 AM   #13
mrhurt73
hmmm hose adaptors, may also be needed before this is over
My Projects-
Old 02-20-2013, 01:40 PM   #14
Custom 68
Custom 68's Avatar
my fix was just a couple bucks at the local parts "help" section. but I am cheap...
Dave
Old 08-20-2017, 08:16 PM   #15
Liltroy
Liltroy's Avatar
For anyone else that might search out this thread.
https://www.youtube.com/watch?v=curX7m9BPeg
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
