Old 02-13-2013, 04:33 PM   #1
caddycol
Hellllllllp ***** brakes
hmmm well every thing is new
7''servo with booster ,proportion valve, new lines cylinders ,callipers, can i get it to bleed can i buggery
did not realise i had to bleed the servo so hooked the hoses up on the side and started pumping its air air air
originally we bleed the system far side rear then worked round to the front fluid flowing but loads of big bubbles
then found out i need to bleed the servo first ( lost count of cars we have built never had to bleed a servo on its own??)
so spent 10/15 mins on the servo still air and a spongey pedal
HELPPPPPPP
in past experience i have had new servos and seals have gone but normally they wont bleed up or only rear/front will let fluid through
ideas please getting fed up of this now ;(
thanks Col the bleeder
caddycol is offline   Reply With Quote
Old 02-13-2013, 06:19 PM   #2
geezer#99
geezer#99's Avatar
Re: Hellllllllp ***** brakes
Are you bleeding the servo correctly?
You need to bleed it back into the servo. Just cracking the lines won't do it as it will draw air back in.
Here's a link to a pic at the bottom of the page.
JFYI over here a servo is called a master cylinder. M/C for short.
http://www.legacygarage.com/prod05.htm
Old 02-13-2013, 06:41 PM   #3
caddycol
yep bleeding it back into it self never had a car like it ;(
Old 02-13-2013, 07:16 PM   #4
geezer#99
geezer#99's Avatar
Possibly bad m/c.
Did you depress the plunger in the front of the prop valve?
Old 02-13-2013, 08:31 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
The servo (master cylinder as it is called in the US) has to be bench bleed before it is installed. You will have to bleed it back into it self when doing it this way. If you do not do this on the bench, then you will never get all of the air out of it.
Check you tube or some other internet sources for the correct procedure. It is very simple but you will need to remove the servo and start over.
TBONE1964 is offline   Reply With Quote
Old 02-14-2013, 09:40 PM   #6
earl84
I did a lot of brake work and had real issues bleeding. I did not have a proportioning valve, but had the same troubles you speak of. I tried vacuum bleeding, the one way brake bleeders, the traditional way, nothing worked. Once I hooked up a homemade pressure bleeder, it was like magic. Worked instantly, went from pedal that went all the way to the floor to a hard pedal. Don't really know how to post a link, but you can copy this url into your browser: http://faculty.ccp.edu/faculty/dreed...eder/index.htm
I used a piece of flat steel and threaded a hole through that, and used a spare master cylinder cover gasket to seal it along with a couple C clamps. Might have been easier and faster just buying one from Motive Products, but hey, it was sort of fun building and it worked, that's all that matters.
earl84 is offline   Reply With Quote
Old 02-14-2013, 09:41 PM   #7
earl84
Hey, I guess I do know how to post a link!
Old 02-14-2013, 10:50 PM   #8
joedoh
joedoh's Avatar
did you make any brake lines? I used a cheapo harbor freight flare tool once and never could get the brakes bled right, replaced the line and bled right the first time.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
