Old 02-13-2013, 05:24 PM   #1
JointTech
JointTech's Avatar
Cheap fixes
I have a monthly truck budget. I usually blow my wad on something big at the beginning and then have 3 weekends worth of nothing to play with... Last month was LEDs, next month brakes, month before was new carb.
So theres always sanding and grinding on the body. ugh.
Throw other ideas out there on stuff that doesnt cost a lot of cash.
clean engine compartment
cleanup wires in engine compartment
body work
rustoleum paint job
window crank grease/oil? might cost money to replace parts though..
fix license plate light
uncrimp and replace with solder some of my wiring messes
polish wheels - going to replace them so dont really want to waste the time but its something to do.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 02-13-2013, 05:29 PM   #2
Billett
Billett's Avatar
Re: Cheap fixes
-headlight relay
-swaybar from the junkyard
-tighten ALL bolts on the frame or bumpers
-polish headlight bezels
-wire side markers to blinkers
-clay bar the paint job
-grease everything
-clean a/c and heater ducts out
-install a mesh under the cowl
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-13-2013, 05:31 PM   #3
JointTech
JointTech's Avatar
Re: Cheap fixes
good list. I just did the headlight relay and wired the sidemarkers as blinkers when i did all new LEDs.
72 C20 Long Bed
Old 02-13-2013, 05:31 PM   #4
1970 C10 MJW
1970 C10 MJW's Avatar
Re: Cheap fixes
while paint isnt exactly cheap... but painting brake drums/calipers control arms, tie rods all that small stuff makes a huge appearance difference even if its just painted black
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 02-13-2013, 05:33 PM   #5
JointTech
JointTech's Avatar
Re: Cheap fixes
good idea. all new brake hardware is in my shopping cart so ill probably spend the first weekend painting it up and install the next.
72 C20 Long Bed
Old 02-13-2013, 05:35 PM   #6
Billett
Billett's Avatar
Re: Cheap fixes
I'm going to be doing some suspension painting too. My brother thinks its a waste of time, but I really think it makes the truck shine. Especially since the engine enamel out of a rattle can holds up well and is pretty cheap around here.
Will
2024 Toyota Sienna
Old 02-13-2013, 05:47 PM   #7
JOJABOY
Re: Cheap fixes
You can always drive up to Palos Verdes and work on my truck. LOL
JOJABOY is offline   Reply With Quote
Old 02-13-2013, 05:51 PM   #8
JointTech
JointTech's Avatar
Re: Cheap fixes
I might do that in exchange for some tuneup training.
Getting nothing on this thread : http://67-72chevytrucks.com/vboard/s...d.php?t=563555
72 C20 Long Bed
Old 02-13-2013, 05:55 PM   #9
Madtat
Madtat's Avatar
Re: Cheap fixes
Joint Tech and Billett just listed the things I've been putting off for the past four months!! Well I did finally get cable!
Good list guys.
body work
rustoleum paint job
polish wheels
headlight relay
-grease everything
* swap out old air in tires for new
Madtat is offline   Reply With Quote
Old 02-13-2013, 09:19 PM   #10
1972RedNeck
1972RedNeck's Avatar
Re: Cheap fixes
Can I ask why?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-13-2013, 11:21 PM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Cheap fixes
* Fill Blinker Fluid.lol
I took brackets off and cleaned and painted them.A drill and wire wheel will make cleanup easier then degrease and paint.I have used brake clean to degrease.
Clean drains at the bottom of the doors.If you lay down under them with them open you'll see the drains.If you have the door panels off clean thru there also.
Paint the inside of the wheelwells.
Very fine steel wool works well to prep the interior surfaces for repaint.I even did a color change.Lots of masking required.
Remove and clean under floor covering,You can clean the carpet or mat well also.
Goop hand cleaner has worked well for me to clean ignition wires with.
Before doing anything else degrease under the hood.Don't use oven cleaner unless you plan on repainting.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-13-2013, 11:29 PM   #12
ARC190
ARC190's Avatar
Re: Cheap fixes
Very good ideas. I'm planning on cleaning out the cluster.
ARC190 is offline   Reply With Quote
Old 02-13-2013, 11:36 PM   #13
Mister-B
Re: Cheap fixes
Clean insides of all windows with glass cleaner
If you've got a cracked windshield or a rock chip in your line of sight, find a glass replacement company that'll waive your $100 comprehensive deductible, and get a new windshield and gasket installed
Buy some Eagle One NeverDull and shine up your metal
Mister-B is offline   Reply With Quote
Old 02-13-2013, 11:48 PM   #14
JOJABOY
Re: Cheap fixes
Cleaned and repainted my cluster a couple weeks ago. Then made some home made cup holders with light. (still have to finish cup holders) Not so much a budget thing here. It just that I am in a leg cast. I do have a laundry list of things to do. I want to go scrounging through the bone yards in Wilmington to see if I can find sway bar stuff and rear bumper next. I figured I will do some paint work in cab and finish up my cup holders next.
I am also planning on:
Herculiner coating the bed
Installing new valve covers I scored off my friend's crate motor
Painting air cleaner and other odds and ends in engine bay
Adjusting my front bumper
New thermostat and flush radiator
Tear apart heater blower, clean, lube and put back together
And I am planning on redoing all my brakes, installing a brake booster and painting underneath
Old 02-14-2013, 08:03 AM   #15
JointTech
JointTech's Avatar
Re: Cheap fixes
i have a flush and fill kit and cant find a place to actually do it without being arrested and deported and beaten by vegans
just refi'd my condo, man i wish i had some land. one day.
72 C20 Long Bed
Old 02-14-2013, 11:36 AM   #16
JOJABOY
Re: Cheap fixes
That sucks. I'm an active duty Marine working M-F at a reserve center in East L.A. I just take my truck into the motor pool and work on it there. All the tools I need plus fluid stuff. Nothing better than servicing your transmission when you have all the right tools and drip pans.
Old 02-14-2013, 01:24 PM   #17
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Cheap fixes
swaybar and relays is the best bang for the buck
John
1999 Toyota Tacoma 4x4
Old 02-14-2013, 01:32 PM   #18
Madtat
Madtat's Avatar
Re: Cheap fixes
Can I ask why?
You change your socks don't you? lol
Old 02-14-2013, 01:36 PM   #19
Madtat
Madtat's Avatar
Re: Cheap fixes
Originally Posted by 1972RedNeck View Post
Can I ask why?
You change your sock's dont you?
Old 02-15-2013, 07:54 AM   #20
Billett
Billett's Avatar
Re: Cheap fixes
This is my exact plan for today.
Also forgot to mention. If you have crud around the edges of your windows like I did grab a flat razor blade and carefully scrape it away. I had a bunch of build up around the bottom edges of the windows and especially on the vent windows. Makes it look a whole lot cleaner once you do.
Will
2024 Toyota Sienna
