02-13-2013, 11:43 PM | #1 |
Warning Lights??
I just figured out were the temp sender goes, now im trying to figure out if i need a sensor with warning lights or the one described as temp guage with guages.
How do i know if i have warning lights? what are warning lights? what does that mean if i have it or not?
1967 C10 Long Bed, Soon to have a 350 1997 Chevy 2500 454 BB |
02-13-2013, 11:54 PM | #2 |
Re: Warning Lights??
Do you have RPO Z53 gauges or U16 tachometer on the SPID? Does the truck now have added factory gauges? If the cluster bezel only has a speedo and a fuel gauge you have warning lights or at least had them.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-13-2013, 11:56 PM | #3 |
If you have the 4 small lower gauges as shown in this dash (i.e. besides the fuel gauge and speedo) - you need the one "for gauges". If you have none of those - you have a warning light instrument cluster - and it will just light up with a warning light when you get too hot vice a needle showing HOW hot you are. (temp gauge is second from the left lower corner - just left of the steering column).
02-13-2013, 11:56 PM | #4 |
oops, sorry tim, simo post
02-14-2013, 12:00 AM | #5 |
i bought a brand new instrument cluster with the 4 smaller guages. I noticed when i bought the wiring harness, there was an option for "with warning lights" i dont remember which harness i bought, if that even makes a difference.
I know i bought the cluster with a tach/oil pressure/volts. i didnt get vacuum. but it is a brand new cluster from classicparts.com
02-14-2013, 12:28 AM | #6 |
The wire harness connector pinout is different between the two types of clusters. Can't tell you off the top of my head but the best place to start is with the harness you bought and checking its part number out.
