Old 02-14-2013, 01:55 AM   #1
stocker96
stocker96's Avatar
Lug nuts?
I have a set of Cobra 20" wheels, problem is I cant use my stock lug nuts, because I can't get a socket to fit into the whole cut for the lugnut in the wheel. How can I get around this? smaller lug nut different style of lug nut? I just spent $800 for tires so I need to find a solution. any help much appreciated.
stocker96 is offline   Reply With Quote
Old 02-14-2013, 04:22 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Lug nuts?
What size of hole. Go to a chrome lugnut that takes a 3/4" socket, instead of the large 13/16" socket. Get a set of tuner lugnuts that use a splined socket. We are using them on the son's Toyota rims and they take up little space.
Frank
piecesparts is offline   Reply With Quote
Old 02-14-2013, 06:02 PM   #3
stocker96
stocker96's Avatar
Re: Lug nuts?
No idea on hole size, I'll check that when I get home. if a 3/4 will fit Ill probably change lugnuts to that. I've had horrible expierence with tuner lug nuts though, so a chrome one with a smaller "shank" is probably my best bet.
Old 02-15-2013, 04:14 AM   #4
piecesparts
Re: Lug nuts?
I ran a set of lugnuts on my wheels of my 91 truck, that were a 3/4" socket size and it is a lot smaller than a 13/16 socket.
Frank
Old 02-17-2013, 06:50 AM   #5
stocker96
stocker96's Avatar
Re: Lug nuts?
ended up getting some slotted ones, work like a charm.
