Old 02-14-2013, 10:39 AM   #1
Baldeagle SR
s10 4x4 frame
Has anyone put a S10 frame and running gear under a 56 1/2 ton chevy? Will a 350 bolt up to the S10 transmission? Thanks Rich
Baldeagle SR is offline   Reply With Quote
Old 02-15-2013, 09:55 PM   #2
Jyman
Re: s10 4x4 frame
The 350 will bolt up to the s10, but it depends on which transmission you have. If you have the one out of the 2.2L 4cyl s10 then nope I'm sorry it does not. but if you have one out of the 4.3L 6cyl s10 then yes it will bolt up.
Hope that helps.
1948 Chevy
305, NV3500, 3.73 rear, sitting on a 95 s10 frame. Still in the works
2000 Chevy Extreme lowrider, 4.3, NV3500, 3.08 rear, upgraded/modded
2001 GMC Sonoma Zr2, 4.3, NV3500, Stock
Jyman is offline   Reply With Quote
Old 02-15-2013, 10:03 PM   #3
Baldeagle SR
Re: s10 4x4 frame
Thanks Jayman for the info. That will help. Now if someone has put a 56 chevy pu on an s10 frame. That would help too. I haven't decided whitch way to go. Rich
Old 02-16-2013, 10:27 PM   #4
waybad
waybad's Avatar
Re: s10 4x4 frame
I'm gathering parts to do just this on my 55 2nd. not sure if i will use the entire frame or clip it? the 91 blazer I have now is a 2 door and the frame is not long enough.. hopefully I will get started by the fall..
waybad is offline   Reply With Quote
