Old 02-14-2013, 11:54 AM   #1
1moretoy
driveshaft angle with pix
will this be ok? the tailshaft out of the transis about 6*. not sure if this is the right way to degree this. trans is a 4l60e w/ls1 out of a 2001 camaro.
1moretoy is offline   Reply With Quote
Old 02-14-2013, 12:03 PM   #2
s_nova69
Re: driveshaft angle with pix
Typically the difference between the tailshaft and pinion should be 2-3 degrees.
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 02-14-2013, 12:25 PM   #3
1moretoy
How should I figure out the difference? Do I unbolt the driveshaft from the pinion and put the angle finder on the flat part. Thanks for your help
Old 02-14-2013, 02:06 PM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Output shaft on tansmission should be the same as the input on the rear end. Also, that driveshaft ought to be into that tranny about 2 1/2" further.
Tom Vogel is offline   Reply With Quote
Old 02-14-2013, 02:35 PM   #5
1moretoy
That is how far it was in on the camaro. Its it at the same ware line on the shaft.
Old 02-14-2013, 03:27 PM   #6
CC69Rat
CC69Rat's Avatar
two piece drive shaft ?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-14-2013, 03:48 PM   #7
1moretoy
Sorry it is a 1pc driveshaft
Old 02-14-2013, 04:00 PM   #8
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Are you at ride height or fully dropped?
Zoomin is offline   Reply With Quote
Old 02-14-2013, 04:38 PM   #9
1moretoy
That picture is with the truck at stock height. I plan on doing bags with ame c-notch. when I do the angle of the drive shaft will get worse I assume.
Old 02-14-2013, 04:42 PM   #10
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Right. Do you have room between the trans and the cab floor to shim the transmission mount?
Old 02-14-2013, 05:07 PM   #11
brad_man_72
the boat guy
brad_man_72's Avatar
Should be 2.5" from tailshaft to center of front ujoint.
Your pinion angle looks fine, for now.. wait you never posted your pinion angle. The trans output and pinion should be parallel. The driveshaft shouldn't be any more than 3* different than your pinion/trans output angle.
brad_man_72 is offline   Reply With Quote
Old 02-14-2013, 05:45 PM   #12
1moretoy
Ok when I get home I will degree the pinion, driveshaft and tail shaft. Is there any special way to degree the pinion?
Old 02-14-2013, 10:59 PM   #13
1moretoy
Ok the tailshaft is at 6* down and the pinion is at 4* up. Will this be ok?
Old 02-15-2013, 12:18 PM   #14
1moretoy
Anybody?
Old 02-15-2013, 12:45 PM   #15
CC69Rat
CC69Rat's Avatar
I think I might shim the trans mount up about 1/4" and re-measure.
Just something to consider, when you accelerate the pinion will rotate down. .. so your 4* up is okayy .. but it will quickly go to 1-2* or so as you pull away from the stop lights.
If I am thinking correctly, if you shim the trans mount up just a hair wouldn't that put them close to equal but not zero'ed out ?
Just to add something else for you.. read through this kit writeup. It will make it all make more sense (it did for me) I know this is S10 stuff, but I promise I used this kit on my 96 S10 ext cab it has ZERO vibration in it anywhere. It is smoother now than it was from the factory. I'm sure the same concept applies to our C10s.
http://www.jagsthatrun.com/Pages/Par...aft-Align.html
Chad
Old 02-15-2013, 12:51 PM   #16
CC69Rat
CC69Rat's Avatar
Just noticed this .. Sorry Big Steve!
Chad
Old 02-15-2013, 01:11 PM   #17
1moretoy
I might have at max a 1/4" to play with. It is pretty tight between the tunnel and trans.
Old 02-15-2013, 01:38 PM   #18
geezer#99
geezer#99's Avatar
CC69.
THe pinion rotates up. THat's why some people install a pinion snubber on the nose of the rearend to limit the upwards travel.
Old 02-15-2013, 01:47 PM   #19
Keith Seymore
Keith Seymore's Avatar
Read through this and see if it helps:
http://67-72chevytrucks.com/vboard/s...d.php?t=522180
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-15-2013, 03:10 PM   #20
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Coils or leaf's?
If your running coils, here is some info for shims. I am running them and they work great.
http://67-72chevytrucks.com/vboard/s...d.php?t=369008
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 02-15-2013, 03:15 PM   #21
CC69Rat
CC69Rat's Avatar
You know what.. youre right. My bad. If youre hanging upside down under the bed doing stunt work.. it rotates down.
Sorry.. thanks for helping me out. Im braindead today.
Chad
Old 02-15-2013, 03:48 PM   #22
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
The trick its to get the angles of the output shaft and the pinion as close as possible to the same and you are you are within 2° which is not too bad. At this point you can shim the trans up if you have room or shim the rear axle. If I were in your shoes, I would get some 2° shims for the rear end and call it good. In a perfect world your drive shaft angle would be less than 3° different than the other angles. However, with a lowered vehicle this may not be achievable. The big question after you get the angles a close as you can is this, do you have a vibration? If not, don't sweat it. Hope my synopsis helps.
What transmission crossmember are you using?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-15-2013, 05:12 PM   #23
1moretoy
Thank you. I think I will drive it first and see if it vibrates at all. Just didn't want to get it all together just to tear it all apart again. If it does I will try and put the shims on the rear end. Do the shims just go under the axel perches.
Old 02-15-2013, 05:14 PM   #24
1moretoy
Thanks to everyone that helped out. This is why I like this site.
Old 02-15-2013, 06:00 PM   #25
C10_ustacould
Yep, the shims go directly under the axle perches.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
