Old 02-14-2013, 02:11 PM   #1
jus2qwk
jus2qwk's Avatar
Step side wheel tubs..(need pics)
Well since my truck is apart and will be getting paint work I think I may go ahead and do some wheel tubs in the bed. I don’t know exactly how I want to do them. I’ve thought about hacking up some fleet side tubs and vie also thought about just doing some plain circular ones. If you guys could show me what you have done that would be great
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 02-14-2013, 02:23 PM   #2
Mike C
Mike C's Avatar
Re: Step side wheel tubs..(need pics)
I'm contemplating the same. The circular ones could be made smaller, but would need to be welded in. I like the ideal of cut and re-welded fleetside wells becuase it seems they could be bolted in place requireing less finish out work. I'd like to do it without repainting my inner bedsides. Look forward to pics of others solutions...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-14-2013, 02:26 PM   #3
jus2qwk
jus2qwk's Avatar
I dont want to repaint the inner bedsides unless I have to. I think what I do will be a bolt in reguardless og which one I go with.
Corey Jones Designs
Old 02-15-2013, 06:46 AM   #4
68Stepbed
68Stepbed's Avatar
You could go either way, but the stock fleetside inner tubs tend to have a more "factory" appearance, but the half circular tubs tend to have a more custom look with a touch of race truck feel. If that makes any sense at all.
I've considered this as well, but I'm just really unsure if I want to cut up my almost perfect bedsides. If I do it, I'll use fleetside inner tubs.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-15-2013, 10:03 AM   #5
jus2qwk
jus2qwk's Avatar
my bed sides look okay now but are and werent anywhere near perfect. so I dont really mind plus a 325 tire would look good setting under there
Corey Jones Designs
Old 02-15-2013, 11:55 AM   #6
68Stepbed
68Stepbed's Avatar
YES it would!!!!!
Matt
Old 02-15-2013, 12:25 PM   #7
69c10step
69c10step's Avatar
Here's mine from No Limit Engineering...
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 02-15-2013, 01:52 PM   #8
jus2qwk
jus2qwk's Avatar
thoes look pretty good.
Corey Jones Designs
