Old 02-14-2013, 03:53 PM   #1
dhughins
dhughins's Avatar
Can anyone ID this power steering box?
Bought from junkyard. Was told mid 80s. Any details you can give me will be helpful. I'm gonna try to put it on my 69 2wd.
dhughins is offline   Reply With Quote
Old 02-14-2013, 03:57 PM   #2
Katrina/10
Katrina/10's Avatar
Re: Can anyone ID this power steering box?
Its a 4wd box, not sure if you can use that on 2wd.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 02-14-2013, 06:09 PM   #3
dhughins
dhughins's Avatar
How to tell difference?
Old 02-14-2013, 07:33 PM   #4
JimKshortstep4x4
The difference is in the pitman arm, location of the pitman arm and the attachment of the pitman arm. The 2wd pitman arm fits on a splined shaft and is held on by a large nut. The 2wd pitman arm points to the rear when the box is centered. On the 4wd the pitman arm is clamped to the splined shaft and points outward to the left with the box centered.
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-14-2013, 10:07 PM   #5
dhughins
dhughins's Avatar
Thanks y'all. I called the junkyard and suppose to swap out for a 2wd. I now see the difference.
