Old 02-14-2013, 05:14 PM   #1
asbiddle377
will 87 body fit k. 76 frame
I got a 87 cab and front end and a 73-80 round opening box all on a 76 frame with 87 rubber mounts and its an inch short lining up with perch for core support and gap between box and cab is already 2 inches wide
asbiddle377 is offline   Reply With Quote
Old 02-14-2013, 06:37 PM   #2
pwradder
pwradder's Avatar
Re: will 87 body fit k. 76 frame
i've seen this same swap done before, so i dont see why it wouldnt work. my first thought is to add a spacer for the radiator support, but i'm not sure what you mean about the cab/ bed gap. does the cab have to go foward? a pic might help.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 02-15-2013, 05:25 PM   #3
wraprail
wraprail's Avatar
How did you get the 87 body mounts to fit the 76 frame? The mounting
Posted via Mobile Device holes are smaller
wraprail is offline   Reply With Quote
Old 02-15-2013, 05:56 PM   #4
asbiddle377
I had to slot the rear cab mount on the frame
Old 02-15-2013, 09:49 PM   #5
Mattman2010
Mattman2010's Avatar
From what I have seen you have to use the correct year mounts as the frame. So in your case use the 76 body mounts on the frame and it will bolt on and should be fine.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 02-15-2013, 09:52 PM   #6
asbiddle377
As in the rubber body mounts?
Old 02-15-2013, 10:02 PM   #7
Nin92
Nin92's Avatar
Yes. The body mount bushings have to the same year as your frame, not body. I put a 86' body onto a 76' k10 chassis using 76' bushings and everything lined up fine.
Nin92 is offline   Reply With Quote
Old 02-15-2013, 10:58 PM   #8
kenbob87
kenbob87's Avatar
just last summer i put a 84 body on a 73 frame, like said before you have to use the correct year body mounts for the frame not the body everything lined up great for me until i went to close the 73 hood on the 84 cab cuz i kept the 73 front clip on the truck i was unaware they changed that part so i just cut out the hood around the wiper arms, then everything worked great.
kenbob87 is offline   Reply With Quote
