Old 02-14-2013, 06:59 PM   #1
spudder
Active Member
Inner Fender Interchange and Differences.......
Which inner fenders will interchange on the '60-'66 trucks? Can an inner fender from a big truck be made to fit a pickup?
spudder is offline   Reply With Quote
Old 02-14-2013, 07:06 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Inner Fender Interchange and Differences.......
all the c10/30 form 60-66 chev and gmc should interchange. the early 'wells 60-61 I think had the spring -perch?- shaped differently than the later ones, but the springs and hinges still mount in the same place, they just look different.
the big truck inner fender is pretty much completely different, the hinge and spring, and the spot it bolts to the firewall on the top is the same, but other than that it is taller and a little bit wider than the small trucks.
Old 02-14-2013, 07:32 PM   #3
jonzcustomshop
1961 crewcab
here are a couple pics of the 60-61, and then the 62-66 c/10-30 showing the spring perch difference.
Old 02-14-2013, 09:13 PM   #4
jbgroby
jbgroby's Avatar
Spudder, Remember to match the spring brackets. early years 60-62ish had smaller frames brackets. 63-66 had larger brackets, look close at the pictures above, you will see the differance.
jbgroby is offline   Reply With Quote
