lowest i can go with 295/50's ?
just as the title says
what is the lowest i could possibly go without having to many issues? i just want to lessen the gap between the tire and the wheel well. please help thanks |
resident oilfield trash
Re: lowest i can go with 295/50's ?
2/4
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
![]() Join Date: Jun 2010
I asked the same thing here a while back. http://67-72chevytrucks.com/vboard/s...d.php?t=564071
I am doing a 4-6 drop and currently run 15x10" rims, so I have to get a different set of rims now. 2-4 was pretty much what I was told as well if you are running the same setup as I am now (before drop). I am still going to run the 295/50's in back but will have to get a rim that has more backspacing. Maybe a 5-5 1/2" BS. My current rims have a 4"bs front and rear.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
![]() 295s rear. About 7-8 drop in rear Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
been here longer than Liz
I did 6/8 with that size on 16s.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
Same here haha forgot to post. My rear are 295/50/16s. I can't find any more anywhere
time for 17's
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
Time for 18s
Diggin The SquareLife
you can do 7" drop rear and clear the tire
Insid, I couldn't find them anymore either. The last time I'd bought them it was a stupid ~$300 each. Went down to 265s.
Parts and more parts
It all hinges off of the backspacing on the rims. I used to run 295/50/15 on the back and a 245/60/15 on the front of my 84 SWB. I now have 17" rims with 275/50/15 tires on the back and 255/50/17 tires on the front. I have a set of 9.5" rims on the back to get the offset that I wanted and the fronts are 8.5" rims to keep the clearance on the front fender. However, there is still plenty of room on my truck. I have a 3.5" drop on the front and a 4.5" drop on the rear and could go more, but would have to 'C' notch the rear frame.
Frank |
#12 | |
#13 |
Look at the Mastercraft tire line. They are made by Cooper Tire and they wear pretty good.
http://mastercrafttires.com/Tires/Pa...venger-GT.aspx
Frank |
#14 |
A tread wear that high I would expect grip would come in wishes and luck. Looks like thier biggest 16 is 235 wide.
#15 |
![]() Join Date: Oct 2009
Pepboys has the Futura SS 295/50r15 for $126 each. You can go as low as you want, lay it on the ground as long as your wheel offset is correct.
#16 |
wow thats a good price on the Futura in that size.
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe |
#17 |
does anyone have any pictures of 2/4 drops and what suspension products they used?
#18 | |
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
#19 |
heres what it looks like i dont have the backspacing needed to go as low as i want and i just want to eliminate the wheel well space if i could id like to put spacers on as well to get a wider stance with the tires get them to stick out at least 2 inches the front already sticks out about 1/2 inch but the rear doesnt i would like to aquire spacers to even both the front and back to stick out 2 inches from the fender |
#20 |
#21 |
This is a truck with a 3" drop in the front with DJM tubular lower A arms and a Belltech 4" drop in the rear. Then we had the springs rearched another 3/4" so that it set the way we wanted it. Front tires originally were 245/60/15 and 295/50/15. Later it went to a 17" rim set up. The red truck in front of the white one has been lowered 3" in the front and 4" in the rear with Bell Tech components, running the same tires combo, as is the black truck.
Frank |
#22 |
that's awesome! thanks
![]() i'm assuming those are 15x10 w/5" backspace and 15x8 w/4" backspace?
#23 |
No actually they are all 15X8 rims. The black truck has a 3.25 backspacing on them and the white truck and the red truck have a 4" backspacing on them.
Frank |
