Old 02-14-2013, 10:00 PM   #1
savatreatabvr
savatreatabvr's Avatar
Missing Factory Emissions Equipment?
I'm getting ready to take my 1973 C20 454 through emissions here in Arizona but I don't have any smog equipment, no EGR, no CATs no PUMP, nothing. The truck originally came with a 350 so I'm wondering if smog equipment was even required on a 1973 C20. I've looked online for a emission parts list for my truck but haven't found anything so any help on this matter is much appreciated!
savatreatabvr is offline   Reply With Quote
Old 02-14-2013, 11:07 PM   #2
KrazyRay
KrazyRay's Avatar
Re: Missing Factory Emissions Equipment?
The 73 with a 454 usually came with no EGR or it had a factory EGR blockoff plate. I don't think it would have a smog pump or tubes on the exhaust manifolds. I may be wrong, but the only thing you need is a PCV. Good luck!
KrazyRay is offline   Reply With Quote
Old 02-14-2013, 11:53 PM   #3
MusicMan70
MusicMan70's Avatar
Here's what my 73 stock 454 looks like; no AIR pump or EGR. Smog pump in California only; I think. This truck was originally from Washington State
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 02-15-2013, 05:03 AM   #4
savatreatabvr
Thanks for the picks MusicMan70! I believe 1975 and up C20s require Cats so I think I'm good there. Now I wonder if my aftermarket air cleaner will pass or do I need the factory air cleaner?
Old 02-15-2013, 10:35 AM   #5
Zane M
It depends on how stringent your testing facility is. Technically the valve cover breather would route into the air cleaner so those fumes would be consumed through the air supply to the carb for combustion purposes.
I have trucks set up like yours, and don't have any issues here in Utah.
Zane M is offline   Reply With Quote
Old 02-15-2013, 11:23 AM   #6
KrazyRay
KrazyRay's Avatar
You will probably need the heat stove on the exhaust with the riser tube going to a stock air cleaner and the PCV going from the valve cover to the spacer above the carb. I've seen 3/4 ton trucks in CA without smog pumps up to 1978, however, I have a stock 1973 1/2 ton with all of the smog garbage on it. The GVW has a lot to do with smog equipment.
Old 02-15-2013, 12:20 PM   #7
rfmaster
rfmaster's Avatar
'75 model year was the last year of no CAT's for HD trucks (engine emission family 113) in CA. You'll need stock air cleaner assembly with heat air for the thermatic valve and air purge tube between air-cleaner and valve cover. AIR injection is required for 75 SBC and BBC trucks in CA. No EGR and that's about it.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-15-2013, 02:10 PM   #8
savatreatabvr
I have a nipple on the bottom of my chrome aftermarket air cleaner, I'm assuming if I run a hose from the valve cover to the nipple I'd be fine, it's doing the same thing as the factory air cleaner, right?
Old 02-15-2013, 06:17 PM   #9
86swb
Born a Chevy Man
86swb's Avatar
Man, I am glad we do not have those emission test here in Kentucky. I do not have any emission equiptment on eather my 86 or 84.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 02-15-2013, 06:29 PM   #10
Karlthegrillguy
[QUOTE=savatreatabvr;5890598]I have a nipple on the bottom of my chrome aftermarket air cleaner, I'm assuming if I run a hose from the valve cover to the nipple I'd be fine, it's doing the same thing as the factory air cleaner, right? [QUOTE]
Yes, run the line to that nipple. As long as it lets air in, your good!
Karlthegrillguy is offline   Reply With Quote
Old 02-15-2013, 07:53 PM   #11
Oilbrnr
Oilbrnr's Avatar
In Maricopa and Pima counties for that year and GVCW all you need is the PCV.
Believe me, I have to do the annual ADEQ dance with my '77 K5 and '80 K20, both of which just escaped many requirements by GM tweaking the trucks ratings in those model years (esp. the K20).
Neither have EGR, cats, evap or smog pumps. Just make sure that PCV system is hooked up and functioning. The air cleaner is fine, but that breather off the valve cover = fail.
Good luck! It is a PITA having to go back if you fail the sniff test.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 02-15-2013, 08:49 PM   #12
Hevy
Hevy's Avatar
Yeah, take the breather off and run the hose from air cleaner to valve cover and you should be good to go, as far as equipment...
Hevy is offline   Reply With Quote
Old 02-15-2013, 09:18 PM   #13
Oilbrnr
Oilbrnr's Avatar
Be prepared for the inspectors to scratch their heads for a bit and possibly refer to the big 'bible' that they have there. My K20 usually always involves the station manager to do the once over as well.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 02-15-2013, 11:42 PM   #14
savatreatabvr
Yes, emissions here in the Valley of the Sun is tough but since we live in a "Valley" where it's rarely windy the smog doesn't get blown away it just hangs over us! I dropped a valve in my '78 Z28 one night and got pulled over blocks from my house for excessive smoke and given a equipment repair ticket! But the biggest contributor to the pollution problem here is the city buses! Phx needed to blow some money so they built an electric light rail system to help with the smog but the buses still run and still smoke!
Old 02-17-2025, 04:31 PM   #15
65chevysub
65chevysub's Avatar
What about my 84 C2500? It was bought new in California but been in AZ since then. I bought it in 2019 and it had a broken EGR and that's it. Plugs in the manifolds, no tubes, or air pump. Had a canister but wasn't hooked up. Engine is an older 350, simple dual exhaust. I put a stock air cleaner on it and have a chrome breather in the valve cover. Currently living in Yavapai County but wanting to move to Tucson. Any help is greatly appreciated
65chevysub is offline   Reply With Quote
Old 02-17-2025, 05:01 PM   #16
72c20customcamper
72c20customcamper's Avatar
Oilbrnr last activity on the site was November 2017 . This thread is 12 years old
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-17-2025, 06:42 PM   #17
karlbenz
I'd just take it in and let them inspect it. They will let you know.
20-30 years old here is safety only. anything over 30 years, no inspection needed at all
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 02-17-2025, 08:42 PM   #18
Keith Seymore
Keith Seymore's Avatar
Need more info.
Need to know your GVW rating.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-18-2025, 01:58 PM   #19
truckin 79
Does your truck still have the original emissions sticker on radiator support? If so most emissions stations will go off of that. I would say most of the youngsters who work in CO maybe even AZ emissions stations have no idea what vintage emissions equipment is supposed to look like, much less what it does. I would just take it in and see if it passes emissions, the number one thing of course is catalytic convertor(s). Once again some young kid looking at a carburetor probably thinks they are looking at a nuclear reactor.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 02-18-2025, 02:38 PM   #20
kglowacky
Texas just put into effect some new inspection/emission laws. The small rural have no more emissions testing but big cities and surrounding areas still do. BUT to my surprise my 78 Silverado has no more inspection at all. Not even a safety check. Just renewed my plates. The idea of antique plates is off my bucket list as it is only a small lc fee that's it. Can drive anywhere
kglowacky is offline   Reply With Quote
Old 02-18-2025, 02:49 PM   #21
Keith Seymore
Just to be clear: emissions sticker goes on the rad support for LD emissions vehicles, because GM certified the vehicle.
HD emissions sticker goes on the air cleaner, because GM certifies the powertrain for HD emissions.
K
1979-1986
1986 - 2019
Old 02-18-2025, 02:51 PM   #22
Keith Seymore
Originally Posted by Keith Seymore View Post
Need more info.
K
The '84 generic info packet in the GM Heritage Center archives does not have this same level of detail, but here is the chart for '86:
1979-1986
1986 - 2019
Old 02-19-2025, 03:20 PM   #23
rodstored-72
chevy truck fan
rodstored-72's Avatar
I know this is old, but I recently ran my daily driven '86 C10 thru emissions (pita) but it passed (LS swap and all). I believe that if the truck is a 3/4 ton (heavy duty) it is exempt from emissions... but not 100% sure. when the registration is due it will let you know if it needs to be "inspected". once done make sure that you "check box" for 5yr sticker!
rodstored-72 is offline   Reply With Quote
Old 02-19-2025, 07:12 PM   #24
Shifty One
Shifty One's Avatar
Not "exempt", but shouldn't be required to have a.i.r. pump/cat/etc...my co-worker has a 77 heavy-half, and he doesn't have to have the equipment (though he has to argue the fact annually), but he does have to pass the sniff.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Shifty One is online now   Reply With Quote
Old 02-24-2025, 03:03 PM   #25
rodstored-72
chevy truck fan
might be... funny story: I drove a '79 "big 10" in H.S. and I remember it had to go thru emissions & I know it had the cat on the exhaust (specifically remember seeing it -due to odd shape) and wanting to remove it for power, but was afraid to get "busted". it was sold here.. chandler (thorobred chevy) and stayed in chandler until graduation & I moved to DFW area......
MAN!! what i would give to find & get it back today!
