Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-14-2013, 10:28 PM   #1
travz500
travz500's Avatar
complete 283 and partial 292
I have complete disassembled 283 all is there heads got wet and will need checked at machine shop they were sitting on wet cardboard possibly pitted the surface would take $200 for motor all is there
the 292 came from a 64 2 ton and ran when pulled missing carb, valve cover, alternator bracket will sell for $125 just want both gone
Pickup only can ship smaller parts if need just parts
travz500 is offline   Reply With Quote
Old 02-15-2013, 07:02 AM   #2
bighunting
Re: complete 283 and partial 292
What did the 283 come out of? And the deck pad code? Thanks
bighunting is offline   Reply With Quote
Old 02-15-2013, 09:13 AM   #3
travz500
travz500's Avatar
It came out of a truck 65 1/2ton 2 wheel drive will have to look at deck code later
Old 02-15-2013, 05:13 PM   #4
travz500
travz500's Avatar
283 block numbers are 3849852 here is a pic of the blocking have everything to put it back together
Old 02-19-2013, 06:21 AM   #5
ksmith59
Hi There
Do you still have the 292?
ksmith59 is offline   Reply With Quote
Old 02-19-2013, 09:19 AM   #6
travz500
travz500's Avatar
Originally Posted by ksmith59 View Post
Hi There
yes I do pm sent
Old 02-20-2013, 12:35 AM   #7
bhc41051
bhc41051's Avatar
Size:  32.4 KB Tavis this is off a 60-63 passenger door it's called a "door sash channel" it holds the rear portion of the glass. You can't tell but it has a hack job repair on the lower part, a captured nut broke and someone tried to repair it...
bhc41051 is offline   Reply With Quote
Old 02-20-2013, 12:38 AM   #8
travz500
travz500's Avatar
Originally Posted by bhc41051 View Post
Attachment 1063427 Tavis this is off a 60-63 passenger door it's called a "door sash channel" it holds the rear portion of the glass. You can't tell but it has a hack job repair on the lower part, a captured nut broke and someone tried to repair it...
are you needing this part? if do have some 60-63 parts doors
Old 02-20-2013, 01:51 AM   #9
travz500
travz500's Avatar
Hi There
the last 4 of the casting is 1970
Old 03-04-2013, 07:40 PM   #10
travz500
travz500's Avatar
292 is SOLD to Ksmith
Old 03-04-2013, 11:04 PM   #11
64LBSS
Still got the 283?
64LBSS is offline   Reply With Quote
Old 03-04-2013, 11:46 PM   #12
travz500
travz500's Avatar
yep sure do
Old 03-06-2013, 11:02 AM   #13
bhc41051
bhc41051's Avatar
Hey Travis, still need the door part but I made a mistake. I need one for the drivers side.... Thanx!
Old 03-06-2013, 12:16 PM   #14
travz500
travz500's Avatar
Hey I forgot about it I will work on that this week
