Old 02-14-2013, 11:27 PM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
Hei?
Forgive me if this is a dumb question
Ic alot of guys are going with hei distributors what do I need for a pretty stock setup 350 I believe it's out of an 80's truck
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 02-15-2013, 01:00 AM   #2
Hardesty454
Hardesty454's Avatar
Re: Hei?
You need the hei distributor... Pretty much it. I have an hei on my big block. Just make sure all your advances and everything are the same as what you're replacing. Makes the swap easier.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 02-15-2013, 01:07 AM   #3
Scott>72-GMC
Re: Hei?
Thanks. I know it was kinda a dumb question never got deep into motors but really want to
Old 02-15-2013, 01:15 AM   #4
luvbowties
luvbowties's Avatar
Smile Re: Hei?
Can use one from any sbc or bbc 1975 & newer--exc. 409 and 348. Run one wire that has full 12 volts when ign. is on and while cranking to "BATT" terminal of dist cap & drive away. Do not use a wire coming from orig. ballast resistor OR one from "R" term. on solenoid.
luvbowties is offline   Reply With Quote
Old 02-15-2013, 01:16 AM   #5
Hardesty454
Re: Hei?
The only dumb question is the one that's not asked. Good luck with the swap, should only take about 20 minutes total. Also, if you've never dug into a motor... Hit up YouTube and search for what you want to do. Tons of genius mechanics on there who show you step by step what to do. But also be weary of the back woods type boys as well.
Rob
Old 02-15-2013, 01:19 AM   #6
Scott>72-GMC
Re: Hei?
You tube is a god send I got a good home mechanic I'm hoping will help me. He has 3 of these trucks one of which. He made into a cool boom truck
Thanks everyone
Old 02-15-2013, 11:52 AM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Hei?
One additional note. You need HEI style plug wires also. The old conventional point style distributor has different ends.
Buy them for a 75 Chevy Pickup with a 350 and you will be good.
TBONE1964 is offline   Reply With Quote
Old 02-15-2013, 01:17 PM   #8
Scott>72-GMC
Re: Hei?
If my truck was here I might not sound so dumb cause I could look lol but I'm sure the motor is out if an 80's truck would it already be set up this way?
Old 02-15-2013, 01:24 PM   #9
Longhorn 70
Longhorn 70's Avatar
Re: Hei?
It could be. The person that put the newer engine in may have used the HEI distributor. I would have.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-15-2013, 01:30 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hei?
Not just the ends, I believe they need to be at least 8mm (OEM points dist. had 7mm) to handle the increased current of HEI.
Also, re-gap your plugs from .035 to .045.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-15-2013, 01:34 PM   #11
Scott>72-GMC
Re: Hei?
He did alot of goofy things. Didn't wire up the alternator left the wires rolled up sitting on the manifold.
Should have never bought from a mechanic lol. Just like my dad being an electrician and our house was a wire nightmare. This mechanic jimmy rigged his own truck lol
