Old 02-15-2013, 10:36 AM   #1
414banger
414banger's Avatar
disc brakes with single master
im doing a disc conversion on my 65 my question is can i run the single master for alittle while while i save for the rest of the job thanks
414banger is offline   Reply With Quote
Old 02-15-2013, 10:42 AM   #2
hopped up
hopped up's Avatar
Re: disc brakes with single master
Pretty sure you need the dual master to run disc. Also need a pop valve to adjust pressure between the front and rear brakes
hopped up is offline   Reply With Quote
Old 02-15-2013, 11:15 AM   #3
Indian113
Indian113's Avatar
I feel that a dual pot MC is the single most safety item you can do to our trucks. They have a disc/drum MC that isn't a power assist if you want it.
Indian113 is offline   Reply With Quote
Old 02-15-2013, 12:33 PM   #4
Lugnutz65
Lugnutz65's Avatar
Tempting as it may be to use the single reservoir MC, DON'T DO IT! Look at any car or truck with disc brakes and you will see they all have a dual MC. In 1967, law was passed that all vehicles needed the dual MC and it's an important safety feature. Don't risk your safety, or the safety of others.
Just my 2 cents.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 02-15-2013, 01:01 PM   #5
64fleetside
You cannot-the OE drum MC has a check valve which will keep pressure on the discs.
64fleetside is offline   Reply With Quote
Old 02-15-2013, 01:08 PM   #6
ljackson
ljackson's Avatar
I agree with above. Switch to dual master. I used this thread to do mine before I switched to power. http://67-72chevytrucks.com/vboard/s...d.php?t=332148
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 02-15-2013, 02:30 PM   #7
414banger
414banger's Avatar
thanks guys looks like a dual master for me then
Old 02-15-2013, 09:39 PM   #8
gimmy 64
the pressure for front and back brakes are differant for disc and drum. if you run it like that you will be only be running one set of brakes. plus the masters are really cheap.
gimmy 64 is offline   Reply With Quote
