Old 02-15-2013, 01:47 PM   #1
Organism_ike
1/2" Manifold vacuum port
Well I've got another stupid little problem holding me back. Im looking for a new threaded fitting to go into the vacuum source on the back of the intake manifold beyween the carburetor and the distibutor. The one I have now is bent to hell, but none of the part stores around me carry any kind of replacement. The configuration of the ports doesn't have to be the same as mine, but I just need one with multiple ports. What do you guys use?
Just to clarify, I am not talking about that brake booster line.
1983 Chevy C10 LWB
305 SBC bored .030 with cast dished pistons
Summit RV Camshaft 204/214 .424/.444
416 Iron Heads
Performer Intake, Quadrajet, and Flowtech Long Tubes
TH350 2.73 10 Bolt
Organism_ike is offline   Reply With Quote
Old 02-15-2013, 05:27 PM   #2
Damon23
Damon23's Avatar
Re: 1/2" Manifold vacuum port
I broke one before but napa had it. You may have to get with rock auto or another online site and order one. I thought they were common. It's just a ported vacuum switch.
Experience is something you gain when you didn't get what you wanted in the first place.
No great defeat was ever just possible in the beginning.
Damon23 is offline   Reply With Quote
Old 02-15-2013, 07:01 PM   #3
geezer#99
geezer#99's Avatar
It's not a ported vacuum switch. Just a vacuum tree. Here's an outrageous one on ebay.
If you go junkyardin' look on Ford trucks. More common on them.
http://www.ebay.com/itm/FORD-Vacuum-...item53f129d5c6
Old 02-15-2013, 08:05 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
http://www.ecklerscorvette.com/corve...1965-1968.html
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 02-15-2013, 08:42 PM   #5
rfmaster
rfmaster's Avatar
Or perhaps this one (APN-0238)
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-16-2013, 10:59 AM   #6
Organism_ike
Pulled one from a 350 pontiac. Actually looks cooler than the original c10 one.
$1 and i picked a couple little things up with it. Always enjoy visiting the local junk yard.
1983 Chevy C10 LWB
416 Iron Heads
TH350 2.73 10 Bolt
Old 02-16-2013, 01:55 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
excellent
1991 GMC Jimmy 4x4
